Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
I have six 7586 Nuvistor tubes, arranged in three pairs so that the heaters in each pair are in series, and each pair is paralleled across the heater supply, 12 VDC from a Eurorack system for modular synths, rated at 1000mA maximum.
Using a 12VDC bench supply, I measured the current draw of the heaters from turn on to quiescent running. At quiescent running the aggregate current draw from all tubes is around 450mA, which will be fine. However, on turn on, the current jumps to over 1000mA, for a fraction of second, before falling down to the 450mA value. I'm worried that this may damage the Eurorack PSU, and wonder whether I should add some sort of current limiter in series with the 12VDC supply to the heaters. The PSU is this one: http://www.tiptopaudio.com/manuals/uzeusps.pdf which itself is powered from a 15V 1000mA wall wart. |
#2 |
Looks like it uses a standard 3 terminal regulator, which normally has built-in current limiting. This will be probably be ok.
#3 |
Or sequence the turn on so they don't all surge at once.
#4 |
The initial current may be greater than 1A. This is quite normal for a valve. Some DC supplies can be caught out if the initial short-lived surge causes an overcurrent trip. Unlikely to damage a PSU as it only lasts for a few seconds, but it might stop the valves from warming up if the PSU stays tripped.
#5 |
Thanks for the advice. I'll give it a try and hope for the best!
#6 |
Your heater current issues are the same that I recently encountered. I wrote a short article about a fairly simple solution:
Unique Tube Heater Supply |
#7 | |
#8 |
This is why I prefer AC heaters.
The start up current is limited by the transformer. So long as the transformer isn't way over sized things will be fine. Quite a few people use DC heaters to get around hum problems. In my experience AC heaters rarely cause hum if heater circuit is implemented properly. I always offset heater AC voltage to about 50 volts DC.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk |
Thread | Thread Starter | Forum | Replies | Last Post |
Thermistors to prevent heater current inrush? | Soothsayerman | Tubes / Valves | 21 | 22nd October 2014 12:16 AM |
Inrush current limiting heater filaments | boywonder | Tubes / Valves | 14 | 2nd February 2009 07:33 AM |
Question on Inrush Current Limiter | pwan | Pass Labs | 4 | 16th April 2006 03:06 AM |
Current Inrush Question - low power xfmr | lgreen | Solid State | 6 | 16th March 2004 05:46 PM |
Elektor amp inrush current limiter question | jgwinner | Parts | 14 | 12th December 2003 04:26 AM |
New To Site? | Need Help? |
