diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Parallel single ended or push-pull? (http://www.diyaudio.com/forums/tubes-valves/28029-parallel-single-push-pull.html)
Jeffy74 11th February 2004 06:07 PM
For about the same output power, do parallel single ended sound better than push-pull? One is easier to build (tube matching or something else...)?
thank you!
Jean-Francois
arnoldc 12th February 2004 12:31 AM
hi, i had exactly the same question yesterday, though i know the basic concepts of each, i'd like to post and get the opinions of the experts here, but the discussion in this thread - http://www.diyaudio.com/forums/showt...&threadid=2883 is enlightening.
Sch3mat1c 12th February 2004 01:19 AM
Depends on if you consider second harmonic distortion up around 3-10% a plus or minus. At the moment I prefer PP but only because I'm a cheapass :whazzat:
Tim
SY 12th February 2004 04:43 AM
P-P will give you lower distortion, higher efficiency, and better power supply rejection.
Sch3mat1c 12th February 2004 05:28 AM
Same efficiency as SE, but distortion cancellation is a wonderful thing. Especially if you have say a class AB SE stage... :bigeyes:
Yes, SE works fine for any other class.. RF amps are tuned, so nuts to the distortion and they can use SE class C... you'll never see class AB SE in audio of course since part of the positive output cycle is um what's the word, missing!
Of course, the wonderful combination of high impedance cutoff conditions and distortion-cancelling PP makes it a wonderfully useful topology.
Tim
Tube_Dude 12th February 2004 06:01 AM
Me to!I also prefer the push pull option!!!
To Jean François!
You will find here ,so many opinions, as people in this forum...;)
Try both!....After that, you will have your own opinion...and you have learned in the process... :)
Salut!!
ashok 12th February 2004 07:04 AM
making a decision.
I guess the best way to go would be to make a PP first.
That way you get a good amp and 'enough' power .
Then make an SE - possibly the best you can stretch and afford.
If that is far better , dump the PP and keep the SE!! At least pick a design that uses the same power tubes .
Do PSE's really suck ?
Cheers.
Resources saved on this page: MySQL 18.75%
