diyAudio Sponsor
Old 11th February 2004, 01:21 AM   #1
amt is offline amt  United States
Default Simple 6BM8 at Evolve Power Amps?
Ive finally started on a Mullard design, suggested here some time ago, and found this while surfing 6BM8 info. This little amp looks very simple and the schematics and layout are very DIY friendly. I bablefished the page but it only did about half and unfortunately, Japanese doent translate very well.
Anyone know anything about this design and if it appears that Tango transfos must be used?
http://www.ne.jp/asahi/evo/amp/6bm8z/report.htm
amt
Old 11th February 2004, 06:17 AM   #2
Fuling is offline Fuling  Sweden
Looking at the schematic, I find it more weird than simple I must say. Whatīs that transistor doing there?
I donīt think Tangos *must* be used, Iīve succesfully used this tube together with many different OPTīs between 5 and 10k primary impedance.
Old 11th February 2004, 06:23 AM   #3
Tube_Dude's Avatar
The transistor is the first gain stage...of course a strange design option...
Or maybe the "best of both worlds"
Jorge
Old 11th February 2004, 07:09 AM   #4
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
You need decent quality output transformers if you want a good sound. Power tranny you can use whatever you can get (for a small tube like this!)
I built the Mullard circuit with NFB and it sounded fine and had plenty of power.
Old 11th February 2004, 10:45 AM   #5
I'll try to post the schematic
Old 11th February 2004, 11:49 AM   #6
It says file to big. No can do
Old 11th February 2004, 11:50 AM   #7
diyAudio Senior Member
fdegrove's Avatar
Hi Joe,
If you like you can send it to me, I'll resize it and post it.
Frank
Old 11th February 2004, 04:08 PM   #8
"Super triode circuits" seem to be very popular is Japan. From what I can gather, they have a Gainclone type of following in that its a new way to utilize commonly available parts.
I wonder how the circuit actually sounds compared to the norm.
And how does a Mullard w/ NFB sound in contrast to the original design? Id like to see ShiFtYs design so I hope it can be posted.
amt
Old 11th February 2004, 08:11 PM   #9
AKSA is offline AKSA  Australia
I've not heard any of the Evolve circuits from Kamijo, but I must say that his huge design repertoire and left field topologies are simply breathtaking. I suspect the man is something of a genius; rarely have I seen anything so original.
He does an EL86 SEPP circuit which I think is seminal, using a triode as a voltage divider - signal into plate, output from cathode - to scale down the negative feedback. And the way in which the two complementary transistors are used for voltage amplification in Rush cascode is astonishing.
His body of work is enormous, and would have taken a lesser man a lifetime of grinding hard work. Not even Julius Futterman matches this range.
Even his presentation, those sumptous drawings, is exceptional. Moreover, he never rhapsodizes about the sound, he simply presents the distortion figures, artefact by artefact, and quietly states that it sounds good. Hell, if he was a politician, I'd vote for him......
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 11th February 2004, 11:13 PM   #10
schematic
Book "Evolve Power Amplifiers" from Shinichi-Kamijo in English ? tiefbassuebertr Solid State 2 13th August 2009 04:22 AM
TCJ - Evolve simply and good amps idea padamiecki Solid State 35 11th January 2007 12:12 PM
Evolve Power Amps lawbadman Solid State 2 1st February 2006 06:31 AM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
Evolve Power millwood Solid State 3 14th July 2003 06:19 AM
Page generated in 0.10954 seconds (76.44% PHP - 23.56% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
