Better place for noise to put the Global Feedback resistor - diyAudio
Old 9th September 2015, 01:10 PM   #1
ygg-it is offline ygg-it  Italy
ygg-it's Avatar
Default Better place for noise to put the Global Feedback resistor
Hello, since the GNF wiring is long, is better to put the feedback resistor (in parallel with a pF capacitor) close to the cathode or close to the OT output?
Old 9th September 2015, 01:14 PM   #2
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Close to cathode.
Old 9th September 2015, 02:27 PM   #3
rayma is offline rayma  United States
Yes, close to the cathode. Always minimize connection lengths to higher impedance circuit nodes.
At the same time, keep the other end of the feedback resistor away from the low level circuitry,
to minimize coupling from the amplifier output.
Old 9th September 2015, 05:54 PM   #4
kstagger's Avatar
This may be overkill, but I often use shielded wire from the secondary to the feedback resistor.
Old 9th September 2015, 06:03 PM   #5
On Hiatus
SY's Avatar
So do I. It also allows the common of the output to be returned directly to the bottom of the input stage cathode resistor, which is the right place for it.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th September 2015, 07:06 PM   #6
I will have to try this. I usually just ground one side of the shield.
Old 9th September 2015, 07:31 PM   #7
On Hiatus
SY's Avatar
Make sure that this is the only ground path for the secondary.
Old 9th September 2015, 08:39 PM   #8
Yes, thanks SY for clarifying.
Old 9th September 2015, 08:40 PM   #9
zigzagflux's Avatar
Good application for cheap coaxial cable.
Best place to put relay? Fusion916 Solid State 5 1st February 2013 10:07 AM
Articles on Global Feedback albertli Tubes / Valves 4 1st February 2010 05:57 AM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
What's the best place to put the crossover? Bricolo Multi-Way 15 27th June 2003 11:29 PM
Feedback network silences op-amp resistor noise mrfeedback Solid State 0 5th April 2003 12:06 PM
Copyright 1999-2017 diyAudio
