Evaluating Tube Diodes as Rectifiers - diyAudio
Old 6th September 2015, 01:30 PM   #1
Default Evaluating Tube Diodes as Rectifiers
I understand that some have used tube diodes as recifiers, even when they are not primarily designed as such. I understand that tube rectifiers are diodes, just specifically purposed to rectify.
What I do not understand is how one evaluates a given tube diode for potential use as a rectifier.
Can anyone shed light on that? Thanks!
Old 6th September 2015, 01:39 PM   #2
DF96 is online now DF96  England
Forward current rating. Forward voltage drop. Power dissipation. Reverse voltage handling. There is no fundamental difference between a 'diode' and a 'rectifier', just that different valves were designed with different purposes in mind.
Old 6th September 2015, 02:26 PM   #3
Ah, so it appears that in some data sheets, some of the necessary information is missing when one tries to repurpose a diode. That makes sense, since it wasn't designed for that reason. Like using a sweep tube as an audio output tube, the values have to be calculated. Is that about right?
So for example, a 6AU4GT. I see PIV and dissipation in the data sheet, but not forward voltage drop or reverse voltage handling. I presume such missing data would have to be calculated?
Thanks!
Old 6th September 2015, 03:57 PM   #4
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Voltage drop depends on forward current but most sit around 70Volts
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 6th September 2015, 04:11 PM   #5
There are many damper diodes in Duncan Amps' PSUII; like 6AU4, 6AX5, 6BY5, and the 6CG3. You can try them out there first.
Old 6th September 2015, 08:54 PM   #6
No. It needs to be measured (or calculated by the original valve designer). In some cases the voltage drop is given as a graph of voltage versus current.
Old 6th September 2015, 09:03 PM   #7
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
The forward drop is nearly always given on the data sheet in the form of the I/V curve. e.g. the last page of this 6AU4GT data sheet:
http://www.nj7p.org/Tubes/PDFs/Frank...nia/6AU4GT.pdf
The PIV and max peak current are the main things that are normally unknown.
Old 6th September 2015, 09:15 PM   #8
So let me ask another way. What would catch your eye when looking at a given tube diode and make you think it might make a good rectifier? And thanks for the replies, everyone!
Old 6th September 2015, 09:20 PM   #9
See my post 2.
If you are looking for something other than electronic engineering as a way of choosing rectifiers then I cannot help you.
Old 6th September 2015, 10:10 PM   #10
Sorry. Never mind.
any reason to use lower voltage diodes or rectifiers? neutron7 Parts 0 16th December 2009 07:04 PM
Free Diodes/Rectifiers richie00boy Parts 0 26th April 2008 02:56 PM
Component Diodes vs. Bridge Rectifiers dfdye Chip Amps 7 22nd December 2005 06:08 PM
Tube rectifiers NickC Tubes / Valves 32 7th November 2002 10:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
