GZ32 vs ss rectifier - diyAudio
Old 2nd September 2015, 09:19 PM   #1
pioux is offline pioux  France
Default GZ32 vs ss rectifier
Is there a way to replace a gz32 by a ss with start delay
Old 2nd September 2015, 11:11 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Consider the voltage drop on a valve rectifier.
Support for Flying Mole Class D, Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 3rd September 2015, 12:22 AM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
Just put a resistor in series with the SS rectifier to get a) voltage drop equivalent to tube rectifier b) lower peak charge current into the filter capacitors, c) less stress on the power transformer
I don't see any need for a start delay unless you have a circuit topology that is sensitive to the power-on.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 3rd September 2015, 01:21 AM   #4
While a delay in B+ rise may not be essential, it's easy enough to obtain. Use a CL-90 inrush current limiting thermistor. The negative temperature coefficient (NTC) device will not delay rise as much as a vacuum rectifier with a cathode sleeve, like the GZ32/5V4, but the delay it provides is usually adequate.
Please post your unit's schematic so the members can make reasonable suggestions as to how the PSU filter should be tweaked.
Eli D.
Old 3rd September 2015, 04:53 AM   #5
azazello's Avatar
Why You will change horse to donkey.....?
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Dario MiniWatt GZ32 tube rectifier Doctorcilantro Swap Meet 1 11th November 2014 04:00 AM
ss rectifier filter recommendate donovas Tubes / Valves 9 24th September 2014 09:34 PM
help testing gz32 gz34 solderon Tubes / Valves 0 25th February 2012 07:57 PM
SS rectifier for SimpleSE and others... cjkpkg Tubes / Valves 2 15th August 2010 01:00 AM
looking for gz32 tube, have NOS to trade smak Swap Meet 0 31st January 2006 08:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
