Will Simple 5687 or Etude 12b4A drive headphones? - diyAudio
Old 9th February 2004, 03:53 PM   #1
Default Will Simple 5687 or Etude 12b4A drive headphones?
I am thinking about building either one of these easy little circuits found on diyparadise.com primarily as a preamp however I would like to know if they could drive headphones too. I asked Yeo, the one who designed and built the projects at diyparadise.com, however he wasn't sure.
http://www.diyparadise.com/simplepreamp.html
http://www.diyparadise.com/etude.html
http://www.diyparadise.com/12B4pre.html
Old 9th February 2004, 08:27 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Much will depend on the nominal impedance of the headphones...
It's a bit like asking if an amp with an output impedance of 1K will drive an 8 Ohm speaker.
So, yes it will make noise but it won't drive it properly as there's a complete impedance mismatch.
Frank
Old 9th February 2004, 08:52 PM   #3
try the projects section in Headwize
There is at least one amp there that uses 5687s and at least one other really good headphone amp.
Converting a yarland amp to drive headphones arvin Tubes / Valves 0 27th February 2007 01:29 PM
Can a 5687 drive four 813's in triode mode ? Fanuc Tubes / Valves 2 15th February 2006 01:38 AM
Suitable Transformer for Etude 12B4A Hewie Tubes / Valves 5 16th December 2004 11:20 AM
Portable direct drive amplifier for ESL headphones shyfx Solid State 6 11th May 2004 10:54 PM
Can BOZ Drive Headphones? vdi_nenna Pass Labs 22 17th September 2001 02:14 AM
Copyright 1999-2017 diyAudio
