ecc99-2a3
Yes,almost the same.The cathode resistor of the ECC99 is changed from 220Ω to 330Ω.
Not much difference, same (allmost) gain.Looks like the 220Ω gives some more linear result.But that's not always better, can be that the less linear solution better cancels those of the 2A3.
Mona
diyAudio Senior Member
Joined 2002
@Ketje. Yes, my thoughts exactly. Still, keep in mind that he puts the ECC99 in parallel if I'm not mistaken.
There's also an integrated version I noticed at the bottom of that page. Too bad the diagram isn't posted.
Also note that the guy insist on using the OPTs made by ESO in France. I have no idea how good these are but they seem to work fine with that design.
Cheers, ;)
