Just finished my new 300B amp - diyAudio
Old 9th February 2004, 10:04 AM   #1
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default Just finished my new 300B amp
in testing phase now
Old 9th February 2004, 10:05 AM   #2
MIKET's Avatar
Default Power supply
see below:
Old 9th February 2004, 10:07 AM   #3
MIKET's Avatar
Default Timer Board
see below:
Old 9th February 2004, 10:23 AM   #4
MIKET's Avatar
Default Power Supply Transformer Details
Transformer is from Toroid Corporation of Maryland
Model Number is 401.040 400VA transformer kit, wininding details to follow soon.
Old 9th February 2004, 10:34 AM   #5
Tube_Dude's Avatar
Why the 10 zenner diodes in the anode circuit of the input valve??
Jorge
Old 9th February 2004, 11:20 AM   #6
MIKET's Avatar
Default Zener Question
To lower the b+ not to excede the rating on the depletion mode FET. I have also updated the schematic to show the bias monitor for the output tube. Set the output tube bias to 60mA.
Old 9th February 2004, 11:21 AM   #7
MIKET's Avatar
Default Schematic Below
1V=1mA
Old 9th February 2004, 11:23 AM   #8
Tube_Dude's Avatar
Default Re: Zener Question
But a resistor will do the same with less noise and increasing the output impedance of the current source...
Zeners are one of the most noisy component in electronics...they produce lots of white noise.
Just one sugestion...
Jorge
Old 9th February 2004, 11:31 AM   #9
MIKET's Avatar
Default Resistor sub for Zener
I will give it a try and let you know what improvement if any is noted, I will keep you posted. I will try a6K 10W resistor for starters.
Old 9th February 2004, 11:36 AM   #10
Tube_Dude's Avatar
Default Re: Resistor sub for Zener
Another point in favor of the resistor is that the mosfet have great parasitics capacitances that shunt power suplly noise to the anode of the input tube...and the resistor help to isolate this parasitic path...
Good luck and keep in touch!!
Jorge
Another 300B SE minhaj Tubes / Valves 10 18th November 2008 03:27 AM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
sub out in my 300b se? Help me please. fergs1 Tubes / Valves 1 4th December 2006 06:17 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
Copyright 1999-2017 diyAudio
