Quicksilver Silver Mono Mods
Old 13th August 2015, 01:16 PM   #1
typereg6 is offline typereg6  United States
Default Quicksilver Silver Mono Mods
I recently purchased a pair of completely stock QS Silver 90 Mono amps based on QS reputation for simple KISS designs and robust buld quality. After living with these for a while I am looking to improve things like "inner detail" and the sense of "spaciousness" in the sound. I haven't had a much luck from the manufacterer and saw several posts helping mod other QS designs but I'm not sure which of those mods would be applicable to this circuit design? I can't seem to find a schematic for the amp anywhere. Any help would be appreciated.
Pics of internals:Click the image to open in full size.
- Can I use KT120 or KT150 tubes in this amp without circuit changes? Should they be biased the same (90ish mA) and would they have significantly extended life over the KT88. Will they produce more power or sound better? (I am sonsidering the Tung-Sol KT120 heavily)
- What would be the best "bang for the buck" approach to improving this amp or let me ask it...where do I start first
Old 13th August 2015, 03:11 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The limiting factor is the mains transformer. Heater current is more on KT150 than KT88 and the transformer will only deliver so much power.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 13th August 2015, 03:30 PM   #3
Is that an issue with the KT120's?
Old 13th August 2015, 03:32 PM   #4
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Hmm--Thats odd, I'm not seeing the O-P, only Jon's reply....
Das Beste Oder Nichts
Old 13th August 2015, 04:40 PM   #5
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Hope this helps:
http://www.quicksilveraudio.com/hist...o100Manual.pdf
http://www.gizmoblog.eu/upgrade-quic...udio-mono-100/
From reading the above link there were problems with this particular model. Not sure if QS corrected this at some point or not.
Frank
Old 13th August 2015, 05:27 PM   #6
These are actually the original Silvef Mono 90's not the 100's
Old 14th August 2015, 09:31 AM   #7
jazbo8 is offline jazbo8
jazbo8's Avatar
Originally Posted by typereg6 View Post
-Why would a manufacturer ask for the power tubes to be bias so high... significantly shortening their usable life
The 90mA~110mA bias is for two tubes. Can you see if the screen grids are cross-connected like the Mono 100?
Old 26th August 2015, 02:26 PM   #8
Yes it is for the pair? Are the coupling caps the ones that connect to the smaller input and driver tubes only?
Old 26th August 2015, 03:39 PM   #9
jazbo8's Avatar
Yes for one pair. I do not understand your second question on the coupling capacitors... Could you post a picture of the output tubes below the chassis so we can see how they are wired?
Old 26th August 2015, 04:53 PM   #10
Badge is offline Badge  United States
I own a pair that I have had for many years. They are highly modified. I suggest you send Mike a e-mail at Quicksilver about tube compatibility. I have stuck with KT88's. I have gone though a number of them in search for better sound. The current favorite is the Gold Lion remakes.
The freaks stick together, they are a tight old crew
Quicksilver Silver Mono ModsHide this!Advertise here!
Quicksilver front end mods Burnedfingers Tubes / Valves 8 11th May 2015 12:50 PM
Quicksilver 8417/12FQ7 mods llwhtt Tubes / Valves 6 22nd September 2008 03:49 AM
Quicksilver mini mono block amps? Burnedfingers Tubes / Valves 2 15th March 2006 12:47 PM
Quicksilver Mono 60 upgrades labjr Tubes / Valves 4 16th February 2005 03:21 PM
For Sale: Quicksilver Horn Mono's BHD Swap Meet 1 10th September 2004 03:18 AM
