Looking for a SRPP Calculator - diyAudio
Old 9th August 2015, 11:42 PM   #1
zlab is offline zlab  Hong Kong
Default Looking for a SRPP Calculator
Hi
I am looking for a SRPP calculator for 12AX7 & 420a, I am not so good to just getting ibea from raw tube information, thanks. I have a project to rebuild first stage of a tube amp and plan to use 420a.
Old 10th August 2015, 12:45 PM   #2
here
Old 10th August 2015, 03:22 PM   #3
Hi
I am sorry to say that this SRPP calculator is wrong.
At least there are 2 mistakes.
1 - Rg2 should be a short
2- the output résistance (at top of Rk2) is much more smaller than the value given by the calculator
Old 10th August 2015, 03:43 PM   #4
Thanks, it’s still a great step forward.
Old 10th August 2015, 04:32 PM   #5
Hi
I would like to say that in order to get the benefit of a low distortion level produced by the SRPP topology, the 2 tubes shall work in the same conditions and for this, Rk2 shall equal Rk1=Rk.
In this situation, the output resistance ( at top of Rk2) is given by :
rs=(Ri/2) * (Ri+(2+µ)Rk) / (Ri+(1+mu) Rk) soit proche de Ri/2
Old 10th August 2015, 05:22 PM   #6
Hi
I have to add that the formula I gave last post is with no capacitor in parallel with Rk1
With capacitor Ck in parallel with Rk1 ( and no capacitor in // with Rk2 ), the output resistance is given by :
rs=Ri*(Rk2+Ri) / (2 Ri+(1+µ) Rk2)
And with capacitor Ck on both Rk=Rk1=Rk2
rs=Ri/2
Personaly, I avoid capacitors and I use a 6SN7 to do the job, less voltage gain but lower output resistance than with a 12AX7.
Old 10th August 2015, 05:29 PM   #7
[QUOTEI am sorry to say that this SRPP calculator is wrong. [/QUOTE]
That is not the only fault in the calculator, as an example Cmiller is wrongly calculated for cathode followers, there can be other faults so be careful when using this.
Old 12th August 2015, 07:20 AM   #8
Default SRPP calculator
The attached Excel table proved to be accurate. Conditions: Rk1 = Rk2, there is no Ck1 parallel to Rk1.
Old 12th August 2015, 09:38 AM   #9
Hi
@Icsaszar
According to the definition of output impedance, it shall not include the load RL as I can read in the file (column L).
Is my reading correct ?
Old 12th August 2015, 12:44 PM   #10
Originally Posted by Hyperman75 View Post
Hi
@Icsaszar
That is correct. The output impedance is the unloaded source impedance. The equations came from the Tube CAD Journal, May 2000 issue, available online. It seems I made a mistake when I put them in the Excel. Uploaded is the fixed version.
Last edited by lcsaszar; 12th August 2015 at 01:02 PM. Reason: error in the calculation
lpf calculator donovas Analog Line Level 7 1st January 2015 07:10 PM
TQWT Calculator chairforce Full Range 4 19th November 2013 01:31 AM
En Vogue Darling SRPP SE SRPP tube amp will this work? pianolydia Tubes / Valves 4 25th August 2013 01:13 PM
Inductance calculator akis Everything Else 14 22nd June 2012 07:00 AM
crossover calculator patriz Multi-Way 4 29th December 2011 11:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
