voltage drops HELP - diyAudio
Old 3rd August 2015, 09:24 PM   #1
Celsius is offline Celsius  Spain
Celsius's Avatar
Default voltage drops HELP
I use one 6sn7 both triodes per channel in cascade coupled by cap, in one channel of the the second stage begin with P 220v RG 220k K 6V with resistor load or CCS at 9mA but after 20 or 30 minutes the voltage drops 2v por minute to P 100v.
Different tubes give the same result
I change the the K resistor R750, same result.
I am going to welding again all pin of the socket, but I would like to know why, I feel really curious.
Any ideas.
Old 3rd August 2015, 10:29 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Circuit?
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 3rd August 2015, 10:55 PM   #3
gofar99 is offline gofar99  United States
Yes please post the circuit. A guess from the clear blue sky would be the one CCS is heating up and becoming non-linear. Usually they go in the opposite direction in my experience.
Good Listening
Bruce
Old 3rd August 2015, 11:22 PM   #4
Check the voltage not with a digital meter but by a scope! if your smoothing cap is damaged, you will see a huge ripple, and a DVM reads less DC voltage, when infact you have a lot of AC.
Also check your AC at transformer taps, when DC voltage has dropped considerably, to make sure it is not your transformer.
Also you could put a 100R resitor in series with supply line, so you could measure current through it when DC has dropped to see if you are drawing too much current.
Circuit definitely helps.
Old 4th August 2015, 05:57 AM   #5
Celsius's Avatar
This schematic is very similar to mine.
only the the fist stage load by CCS 10m45 and the second I tried both resistor and CCS with the same problem. this problem begun after I rewire the socket, solution is easy rewire again, but I feel really curious to know why.
Old 4th August 2015, 06:36 AM   #6
Celsius's Avatar
Ha ha ha the couple cap between 6sn7 is the guilty, begin to don't stop the DC from the first stage plate to the grid of the second stage. the bias run from 6v to 0v and the voltage plate run in the same direction reducing the voltage to give the 8mA.
Resolved thanks
Old 24th August 2015, 08:07 PM   #7
Celsius's Avatar
Default The problem follow
After holidays I have checked again the 6sn7 grid of second stage and I have again the same problem, the voltage of the plate drop because the grid of the second stage have DC voltage.
Begin wit 0,3v after 30 minutes have 4V only in one channel.
I have change the 10m45s of the plate, the cap between the stages and the problem follow.
Ideas why?
Old 25th August 2015, 01:09 AM   #8
Chris Hornbeck's Avatar
Another bad cap? Same batch? But first swap tubes between channels to eliminate them as the problem's source.
All good fortune,
Chris
Old 25th August 2015, 08:33 AM   #9
DF96 is offline DF96  England
What caps are you using? Voltage rating? (Need over 400V for that circuit). Dielectric? (Avoid paper, as it absorbs water and becomes leaky). New? NOS?
Old 25th August 2015, 09:14 AM   #10
Celsius's Avatar
Never is only one guilty.
Wax oil caps 1000v 0.22uf when begin to heat begin to give same DC 0.4v to 1.5v. To check the amp the position is upside down and the temperature inside the amp is higher that in the standard position.
the old Raytheon 6sn7, one of them, has a problem and the grid have 3v dc more in the grid that the other channel.
I was crazy to find the problem, when I put the Teflon 400v 0.1uf K72 cap and the problem following don't understand what happened. After replace the Tubes and the Teflon cap all is (seem) running perfectly with 0v ( at the moment )
Heater voltage drops? vintvolt Tubes / Valves 5 9th July 2012 03:58 PM
Output of preamp drops when overdriven oliverwestby Tubes / Valves 7 1st February 2009 02:36 PM
Re: Why voltage drops with very small load? Aaron323 Power Supplies 9 17th February 2006 12:02 AM
bypassing dayton with orange drops? crippledchicken Multi-Way 3 14th March 2004 09:24 PM
BOZ supply voltage drops to 1/2?? Kermit Pass Labs 11 11th December 2002 07:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
