Help me ID these tubes - diyAudio
Old 1st August 2015, 01:22 AM   #1
Default Help me ID these tubes
Please help me ID these tubes. Over the years the labeling has flaked off the sides and the tube boxes are long gone. So not sure of the manufacture. I got these in the 80s. I believe they are both 12AX7. My tube tester is currently not working, so without building a circuit, I'm not sure, but both were working last time I checked. Both tubes have a diamond etched in the glass on the flat bottom, one is 51, with a 2 under it, the other is a 2, with inverted 2 under it. Is there any hope of figuring out what they are?
Old 1st August 2015, 04:25 AM   #2
My Telefunken tubes do not look like that. There are 3 ridges going across and 2 on each side. The holes in the plate are bigger with the top and bottom both pressed in.
A RCA I have has ridges on the plate, along with a GE. Then I have a GE and Motorola with smaller plates.
Some Telefunkens have smooth plates, like the ones made for Fisher and Dynaco. Look at pictures for those.
Old 1st August 2015, 05:19 AM   #3
Smoothplate TFK ECC83?
Eli D.
Old 1st August 2015, 12:47 PM   #4
Alastair E's Avatar
Looks a bit Japanese to me--especially the getter....
Maybe Hitachi?
Das Beste Oder Nichts
Old 1st August 2015, 02:19 PM   #5
From what I can recall...they had white markings, like Bugle Boy, or Mullard. Pretty sure they were not Japanese. I was into buying NOS American or European. I was thinking they were Tele smooth plates? That doesn't mean the where not built for someone else, and relabeled, by one of the major manufactures. Does anyone know a trustworthy place I could send and have tested and verified what they are?
Help me ID this trafo and tubes.. Junm Tubes / Valves 10 31st October 2013 02:46 AM
Help ID tubes Plz JRGuitarGuy Tubes / Valves 11 11th October 2012 02:47 PM
help ID 4-500 old stock tubes squarehdca Tubes / Valves 3 25th September 2010 09:26 PM
help on id of tubes woodturner-fran Tubes / Valves 8 14th March 2006 10:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
