Bias Probe Question - diyAudio
Old 28th July 2015, 10:38 PM   #1
packer is offline packer  United Kingdom
Default Bias Probe Question
Hi All,
I have 4 bias probes installed in a Marshall amp that uses EL34's
Two of the EL34's share an internal 1 ohm resistor between the cathodes and gnd
My question is are/will these 2 1R resistors affect the measurements of the bias probes at each of the probs have a 1R resistor in series with each of the cathode pins.
Old 29th July 2015, 12:23 AM   #2
jjman is offline jjman  United States
If you are using the "probes" that are like sockets, there is no issue. I would compare the socket probe results to the internal "probes" ( 1Rs ) to verify the results.
Old 29th July 2015, 07:41 AM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Marshall expect owners to use matched quads or pairs of output valves, so no need to check all of the cathodes, if running cool, aim for about 50mV across the 1R or 100mV if you want t Fender warm sound. NOT EACH VALVE! each pair.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 29th July 2015, 03:25 PM   #4
I have a matched quad of Marshall VLV00010 (EL34) installed bias is good and stable at 45mv per plate which is great for a TSL100 !
When i put the Bias probe adaptors in the measurement run high and are unstable.
( bias probes have been checked and are in calibration ( bias probes are TAD BM4).
Could the fact there are 2 1R resistors in series with the cathodes upset the readings that much? 1 resistor for 2 cathodes in the amp and 1 resistor in each of the probes.
Oscilloscope probe question fireworks Equipment & Tools 6 29th July 2015 12:12 AM
Oscilloscope/probe question ouverview Equipment & Tools 4 23rd March 2010 09:32 PM
Oscilloscope/probe question ouverview Equipment & Tools 1 22nd March 2010 07:04 AM
10x probe question NEO Dan Parts 5 22nd October 2008 03:40 AM
Please need help! TUBE BIAS PROBE fiendish Tubes / Valves 3 11th April 2007 06:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
