Not suitable for a pre amp. EBF32 is a double diode pentode for frequency changing in radio sets. EF39 is an RF amplifier, ECH35 is a triode hexode frequency changer and EL33 is the little brother to the EL37. Two can produce up to 8Watts at no more than 15% harmonic distortion.
Gain from a 12AU7 and a 12BH7 are approx. equal.
Do you want an effects machine or a HIFI setup? Search the archives for 12B4 designs. The 12B4 is both linear and low μ (amplification factor).
BTW, what is the I/P impedance of your SS power amp? As low as 10 Kohms is within the IHF "standard". The 12B4 is one of a very small number of tubes that can drive such a low downstream load successfully, when wired as a common cathode gain stage.
you might get away with it in triode mode though....http://www.r-type.org/pdfs/el33.pdf
g1-g2 mu of about 20 is like that of the 6sn7, but that is all...
please have a look at the diyaudio thread where the 6V6 is used as a line amp...http://www.diyaudio.com/forums/tubes-valves/102352-6v6-line-preamp.html
so there you go, go build a line amp.....
btw, since the pinouts are the same, you can even roll between the two....
What is "best"?trean27 said:by the way, what tube should I buy to get the best sound specially for Rock music.
Drop it on the floor. If it just bounces then drop it again. Eventually you will hear the sound from the tube. Onlookers may hear the sound from the tube owner too.I would like to benefit from the sound from the tube..
12B4 is great.
I just built this - easy project and a nice clean sound.
diytube.com • View topic - Budgie Preamplifier w/ Arduino - 6/23/14
The ECC85/6AQ8 closely resembles the 12AT7/ECC81. Given the reasonably high transconductance (gm), a stereo buffered (cathode follower) volume control could be made from a single specimen. Well executed, the setup would be highly transparent. However, the OP has yet to answer my question about wanting linearity or an effects box.
- Tubes / Valves
- Tube Preamp philips Mullard
