B&K 747 troubleshooting - diyAudio
Old 23rd July 2015, 08:51 PM   #1
Default B&K 747 troubleshooting
Hi, I bought a B&K 747 tester on eBay that arrived today. It was advertised as fully functional.
So I went to test a 12AX7 and followed the Manual exactly. The tube tested normally and everything was fine.
But after that it just stopped working. The pilot light is on but I can't get a single tubes filament to even light at all
I've tried many different NOS tubes and multiple sockets and everything is not working.
Any idea what might be the problem?? I'm thinking I should just return it if it isn't an easy fix. Thanks!!
Old 23rd July 2015, 10:06 PM   #2
HollowState's Avatar
If tubes don't light, the first thing to check is an internal fuse in the filament circuit. You can see it in the attached schematic at the bottom of the filament winding.
File Type: pdf B&K Model 747 Dyna-Jet Tube Tester Schematic.pdf (157.5 KB, 15 views)
"The further a society drifts from the truth, the more it will hate those who speak it" ~George Orwell
Old 25th July 2015, 08:56 PM   #3
Update: Checked the fuse, it has good continuity so I guess that's not the problem...
I did find one resistor that looked burnt and was cracking, so I replaced that but the problem persists. Any ideas on what might causing the issue? Thanks!!
B&K model 747 tube tester for EL34 ivershing Tubes / Valves 13 11th April 2015 08:42 AM
B&K 747 tester...Problems Help! Freecrowder Equipment & Tools 3 9th April 2015 09:00 PM
B&K 747 tube tester tigro Tubes / Valves 2 24th November 2009 01:04 PM
Help-Troubleshooting & schematic for older NEC A520E amp VictoriaGuy Solid State 14 7th April 2009 07:40 AM
WTB: Grace 727/747 headshell slydwz Swap Meet 0 28th June 2005 01:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
