Tube rectifiers also need snubber capacitors? - diyAudio
Old 22nd July 2015, 11:33 PM   #1
rongon is offline rongon  United States
rongon's Avatar
Default Tube rectifiers also need snubber capacitors?
When using silicon rectifier diodes like 1N4007 for tube amp plate supplies, people put film capacitors from the anode to the cathode of each diode, to suppress noise from switching spikes.
I've read that contrary to the common wisdom, tube rectifiers (like the 5Y3GT I'm using) also create those switching spikes. If that's the case, then it should be helpful to put something like 10nF to 100nF from each diode to the cathode of the 5Y3. Has anyone tried this? Any results to report?
Some questions:
- What capacitor type is best for this? I would think polypropylene film and foil construction would be best, since that's the type that's rated for the highest ripple currents. Can metalized polyethylene or similar also be used for this? Ceramic dielectric 1kV parts?
- What voltage rating do the caps have to have? If for a +400VDC supply, would a 630WVDC rating be enough? Or is 1kVDC necessary?
____________
Old 23rd July 2015, 03:22 AM   #2
zigzagflux's Avatar
It is possible the snubbing you have heard recommended for tube rectifiers is actually the result of transformer ringing, rather than reverse recovery switching noise which occurs in semiconductor diodes. These are different issues, and are addressed with snubbing in different locations. I would suggest snubbing any transformer that is used with rectification regardless of rectifier type.
The snubber consists of a series RC network placed in parallel with the transformer secondary winding. There are alternative locations with varying degrees of success, but I have found this to be the ideal location.
The capacitors you are referring to (directly across the diode) are to address reverse recovery.
Metallized polypropylene is my suggestion, with an AC voltage rating appropriate for the secondary winding. Resistor is either carbon comp or some other low inductance technology.
Old 23rd July 2015, 07:35 AM   #3
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
As zigzag says, any rectifier can suffer from transformer ringing, but it will be much less with a valve rectifier because its internal resistance inherently damps the process. But an RC network across the secondary will do not harm. The component type does not matter. Normally you would use a ceramic cap because they're readily available with kilovolt ratings. You can use a plastic cap if you want to but don't expect it to create a holographic soundstage or anything. Use about 10nF, then add a resistor (doesn't matter what type, the inductance is negligible) to tune out the ringing. If you don't have the means to do this, just use a value between about 1k and 5k, which is likely to do most of what you need.
Old 23rd July 2015, 08:32 AM   #4
DF96 is offline DF96  England
Any switch can create switching spikes. Only certain solid-state diodes produce reverse-recovery spikes.
Given that valve rectifiers turn off gradually I would not expect a problem with them. However, adding a cap with constant AC stress may reduce PSU reliability. Best to do nothing unless you can identify a real problem which then needs solving.
Old 23rd July 2015, 02:56 PM   #5
rongon's Avatar
Thanks for the replies and clarifications. Much appreciated.
So, if I see ringing in the power supply feed, that would be from transformer ringing. That can be tamed by a series RC between the transformer secondaries. Most likely will use 10nF (1kV rated) and resistor between 1k and 5k.
However, putting a capacitor between the secondaries means that part will always be seeing high voltage AC pulses. That adds a possible failure mode. So if it ain't broke, don't fix it! (Good point, DF96.)
From reading the old RDH4 and a couple of other old books, I found that resistors are often put in series with the plates of the rectifier tube to decrease current pulses to the tube. This is useful for ensuring longevity of the tube, especially if using a fairly large value of reservoir capacitor (I'm using 47uF 450V). I was thinking of putting 100R in series before each plate (pins 4 and 6 on the 5Y3GT).
I figure 1W rated parts will do. My thinking:
Plate supply draws about 40mA total.
100R * 0.04A = 4V (dropped across each 100R resistor)
4V * 0.04A = 0.16W (power dissipated in each 100R resistor)
I figure the 1W rated parts give lots of headroom.
Advisable?
Old 23rd July 2015, 03:59 PM   #6
Some diyAudio members are especially conservative when designing circuits that connect to power transformers in vacuum tube equipment. They feel it necessary to assume that a bunch of worst case scenarios eventually will occur, simultaneously
  • IT IS ASSUMED the equipment contains no surge protectors, MOVs, gas discharge tubes, transZorbs, or other countermeasures. The entire upstream chain of power strips and power conditioners and plugs and jacks, is also devoid of surge protectors and lightning suppressors, all the way to the utility company's transformer on the pole. The whole chain does absolutely nothing to limit voltage surges on the mains
  • IT IS ASSUMED a surge of at least 1000 extra volts WILL occur on the mains, while the equipment is turned on and playing music through the speakers
  • IT IS ASSUMED the surge WILL pass from the transformer primary (times the turns ratio) to the secondary; you cannot depend on the transformer to act as a lowpass filter when the manure hits the fan
These folks conclude that you need at least 1.6 kilovolt rated capacitors for across-the-line AND for across-the-secondary applications (such as transformer ringing snubbers). Furthermore, they insist that you must use flameproof resistors in both the primary and the secondary circuit, because a nanosecond-risetime, 1 kilovolt surge will instantly vaporize any and all resistors. Even snubber resistors in the secondary. WHEN, not if, those resistors get blasted, you want to make sure there's no fire.
Me, personally, I think this is a bit too conservative for my tastes. While I agree that following these guidelines will make the equipment more robust, I think I prefer to spend my "ridiculous overkill" budget on other areas of the circuit design. No 1.6 kilovolt snubber caps for me, thank you. Flameproof resistors, sure, why not; the cost increase is negligible.
By the way, readers may enjoy independently analyzing the old wives' tale that you should use only carbon composition "low inductance" resistors for snubbers. Here's the data you need to carry out the analysis: (i) maximum frequency of resonant oscillation is 3 MHz and often much much lower, especially in vacuum tube HT windings; (ii) typical values of optimum snubber resistance (Q<0.5) for high voltage secondaries, range from 200 ohms to a maximum of 2000 ohms.
There you go. That's everything you need to calculate a value of parasitic series inductance which becomes non-negligible (more than 10% of the resistor value) at the resonant frequency. It's a straightforward piece of arithmetic and if you use the values above you'll get a number of microhenries. Not nanohenries, microhenries. Metal film resistors, carbon film resistors, metal foil resistors, surface mount resitors, just about any kind of resistor except wirewound resistors, have series inductance measured in nanohenries. Three orders of magnitude lower. Conclusion: in a snubber feel free to use whatever resistor type you like, as long as it's not wirewound. Let grandpa stay with his humidity-absorbing carbon composition resistors if he likes; YOU don't need to.
Old 23rd July 2015, 04:32 PM   #7
You are equating DC current draw with AC RMS current. There is a factor of 2-3 to be used. This means 4-9 in power terms. As a minimum, I would assume 5 times as much power dissipation in the added resistors as a naive calculation gives.
Old 23rd July 2015, 06:09 PM   #8
rongon's Avatar
Thanks once again, DF96.
I need to find someplace that explains how to predict power dissipated in a load with AC voltage across it. This could be useful for speaker power and all sorts of things.
I'll use 5W resistors, for sure. Fortunately, I have some 100R 5W 'cement box' types.
Old 23rd July 2015, 06:18 PM   #9
That is easy: it is V^2 /R, just as for DC, but you have to use the RMS value.
Similarly, it is I^2 R for current - but again you use the RMS value.
For sinewaves RMS = 0.707 x peak. For square waves RMS = peak. For other AC waveforms you have to do a somewhat messy calculation, or get a computer to do it for you!
Old 23rd July 2015, 06:47 PM   #10
Keep a couple of formulas in mind.
V = IZ The AC form of Ohm's Law.
Z = (R2 + {XL - XC}2)1/2 Where XL is the inductive reactance and XC is the capacitive reactance. Impedance is a complex, not real, number.
AC power = (V) (I) (cos[n]) Where n is the phase angle between the current and voltage vectors. This is the scalar (dot) product of the vectors.
In a pure reactance, the phase angle is 90o and the power is zero. Power is dissipated only in a resistance.
Eli D.
Adcom GFA-2 recap....should I replace rectifiers/snubber caps??? j.burtt Solid State 3 14th January 2015 10:21 AM
Snubber caps with sic rectifiers? john dozier Power Supplies 1 25th June 2012 10:31 AM
GE Snubber, High Current DC, and Switching Capacitors DualTriode Tubes / Valves 2 17th July 2011 05:23 PM
[SG3525 smps] Input capacitors puffing after adding snubber aliazhar Power Supplies 36 21st November 2009 08:59 AM
Snubber capacitors choice youyoung21147 Power Supplies 10 27th November 2005 08:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
