Opt primary impedance for audionote M10 phono pre - diyAudio
Old 18th July 2015, 06:09 PM   #1
noyan is offline noyan  Turkey
Send a message via Yahoo to noyan
Default Opt primary impedance for audionote M10 phono pre
Hello,
I am planning to build M10 tube preamp. Does anyone know the primary and secondary impedance values of the output transformer?
http://www.diyparadiso.com/schemas/p...0duidelijk.gif
Old 18th July 2015, 10:29 PM   #2
Koonw is online now Koonw  Malaysia
Audio Note
TRANS-027 impedance ratio 33:1 or 19.8K:600
Can use Tango np126 or Lundahl LL1540
Old 18th July 2015, 11:51 PM   #3
Here is additional info on Chinese web site
Trans 027 data:
PRI DCR 397,Inductance 110H,Sec DCR 20 Ohms *2 , Impedance ratio 33:1
Old 19th July 2015, 01:49 PM   #4
Thank you very much!
Lower the primary impedance of the OPT to reduce distortion? Alan0354 Tubes / Valves 114 12th January 2015 02:45 PM
Push Pull OPT Primary Impedance ballpencil Tubes / Valves 9 11th November 2014 06:42 AM
Any idea what the primary impedance of the X101-B OPT is? jmillerdoc Tubes / Valves 6 1st April 2010 01:56 AM
Asymmetrical P-P OPT Primary rdf Tubes / Valves 14 11th March 2007 10:46 PM
audionote 144 OPT comment pls... calico88 Tubes / Valves 0 13th September 2006 10:02 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
