Possible to make a KT88 PP UL schemat OTL ? - diyAudio
Old 5th February 2004, 01:17 PM   #1
Default Possible to make a KT88 PP UL schemat OTL ?
I was thinking of a coupling capacitor to drive 8ohm, 16 ohm is my limit??
Any ideas on this schemat?
http://www.plitron.com/pages/Products/Audio/vtvkt88.htm
I know i've been knocking this schematic in many threads for the past month but I was considering removing the fact that I may have to import /all/ of my trannies and components just because local supply doesn't have /exactly/ what I need aswell as having a sweet-tooth for low-cost and good-sounding transistor OTL amps :P
I know I can source a local PT for the B+ of either side but I'll have to scratch my own 70v Bias supply and I would have to use a completely different filament supply as I couldn't use the single 6.3v 5a winding from the proposed centre-tapped modification that I've recently planned..as the transformer is supplying 'two' channels and is only wound for about 5a..not 10amp :P
Okay i'll promise not to post for 2 full weeks unless I have a reeely good explaination :P
OH and I'll make this thread a free-for-all for anyone to add their suggestions...
I've already got down a few from the last thread so I know not to use Carbon based resistors and that 8uF caps in place of the 10uF ones "won't matter" and that I can feed two amps B+ with only one power transformer with a CT...
Add your suggestions! reguardless of what they are and I'll fly them past a local (not to be disturbed unless via appointment) veteran to make sure I aint going to blow things up :P, besides I learn much faster from him explaining and sometimes demonstrating! infront of me than I could ever do reading... at least reading allows for writing which in turn allows me to remember some things :P
The best thing although I have found is to have a really thick yet portable notebook!!! I can't stress that enough!
Old 5th February 2004, 01:36 PM   #2
SY's Avatar
My suggestion is that if you want to build an OTL, build an OTL. Trying to adapt a circuit made for a totally different application will be quite frustrating- and at the end, you'll have something expensive, inefficient, and poorly performing for all the labor you put in.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th February 2004, 02:00 PM   #3
Ok then so this thread is to be used for suggestions for modifications to the original transformer amplifier design...
Is this circuit running the KT88's Class-A ? if not how can it be done with this schemat?
Old 5th February 2004, 02:59 PM   #4
SY's Avatar
For class A, you need to drop the B+ significantly- about 350 volts would work- and increase the idle current to about 90-100 ma per tube. You'll shorten the tube life, increase the heat output, and greatly reduce the power, but you'll have Class A, fwiw.
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 11:08 AM
New EL84 SE schemat. Layberinthius Tubes / Valves 1 18th July 2004 06:38 AM
Compact All-In-One Chassis Design with good ventilation. And low noise, Not a Schemat Layberinthius Tubes / Valves 13 29th February 2004 01:35 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 01:24 PM
Copyright 1999-2017 diyAudio
