Old 5th February 2004, 10:42 AM   #1
Send a message via ICQ to ackcheng
Default Using 12 EL519 for T8
Dear Sir,
I am just thinking if I use 12 EL519 for a Transcedent T8 instaead of the original 8 inorder to increase the power. Should I change the spec for the fuse? I am going to use two 300VA transformers in parallel to deliver 135V-0-135V. (The origianl deisgn was 120-0-120 but I can only find the 135-0-135 availble. I will change the bias resistors)
Arthur
Old 7th February 2004, 01:09 AM   #2
diyAudio Senior Member
fdegrove's Avatar
You'll end up about 15VDC too high so I suggest you put a dropping resistor between C18- C20 and C19- C21 respectively.
Is that a 500mA Slow Blow fuse?
If so, go for the next one up if you see the fuses blow for no apparent reason.
Frank
Old 7th February 2004, 11:18 PM   #3
icebear is offline icebear  Norway
Default Va
Doesn't VA stand for Voltage Ampere, which means Watts?
Has not really anything to do with the actual voltage you get from the transformer.
Am I rigth?
Old 7th February 2004, 11:40 PM   #4
fdegrove's Avatar
Yes, only that's not the problem.
The point is that the original xformer is 120V-0-120V, not 135-0-135V.
Frank
5x EL519 ErikdeBest Swap Meet 1 28th October 2008 01:36 PM
Wtb : El509, El519, 6lf6 ANALOG GUY Swap Meet 0 13th July 2006 04:13 PM
EL509 vs EL519 resident Tubes / Valves 3 15th November 2004 02:01 PM
EL519/KT90 The old debate Alastair E Tubes / Valves 8 8th March 2004 08:46 AM
schematics for a EL509/ EL519 PP amp needed NotInTheMafia Tubes / Valves 15 15th December 2002 08:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
