what film capacitors do you use? what film capacitors do you use? - Page 4 - diyAudio
Old 7th February 2004, 02:44 AM   #31
Magura is offline Magura  Denmark
Magura's Avatar
Take a look at this thread. It shows a little about magnetics influence on a circuit (or the lack of).
http://www.diyaudio.com/forums/showt...298&highlight=
Till now nobody have been able to come up with more than theories about the existance of such a problem.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 7th February 2004, 03:01 AM   #32
millwood is offline millwood  United States
Account Disabled
Originally posted by fdegrove
Copperweld is magnetic as it contains iron(?) particles....
Originally posted by marz.tv
What is the chemical designation for copperweld? Or the Swedish term if there is one.
copperweld was part of LTV that survived the bankruptcy of LTV. It makes mostly tubing, but started its life as a manufacturer of copper clad steel and aluminum wires. such wires offer the electric conductivity of copper (copper outside), with the strength and low-cost of steel, or light weight of aluminum.
Since copperweld isn't an alloy, you cannot exactly call it a "chemistry" as you would to steel.
what film capacitors do you use?Hide this!Advertise here!
Film capacitors for decoupling rotation Parts 4 6th November 2007 08:02 PM
Favorite film capacitors for DC blocking? The Peasant Parts 18 1st December 2006 04:37 PM
SCR film capacitors?? kimschips Parts 2 19th June 2005 01:25 PM
what are the film capacitors? Wagener Solid State 2 5th May 2004 10:23 PM
Acrylic film capacitors JohnG Parts 2 6th February 2003 01:49 AM
Copyright ©1999-2017 diyAudio
