What the hell caused this? - diyAudio
Old 7th June 2015, 04:44 PM   #1
john65b is offline john65b  United States
john65b's Avatar
Default What the hell caused this?
I turned on my system this am to hear a nasty hum...both speakers. I quickly shut everything off and swapped preamp - all was fine - no hum. I looked at my preamp (Aikido all in one 6922/6H30) closer and found one of the two 6922 input tubes smoked on top - after looking a little closer saw a gaping hole in bottom of tube at the knuckle...what the hell would cause this? I am glad I did not destroy anything in my system....replaced the EH6922 and all good again..
See pic... bad manufacturing defect? The pre has not been moved for months....
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 7th June 2015, 04:47 PM   #2
lexx21 is offline lexx21  United States
Most likely just a defect in the glass.
Old 7th June 2015, 05:38 PM   #3
HollowState's Avatar
Air leaking in does happen to the best of tubes. And it hurts when it affects the expensive ones.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 7th June 2015, 05:41 PM   #4
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Suspect other members of your household...
Old 7th June 2015, 06:23 PM   #5
you did not get the WAF approval on the tidyness of your speaker cable layout...
and she kill your belove tube in an act of retributive justice
hihihi
Old 7th June 2015, 06:53 PM   #6
hates ground loops
Rodeodave's Avatar
The white stuff is the oxidised getter metal that was disposed on the top section of tube's interior surface. The tube must have drawn air somehow. A bent pin will do that sometimes...
Gravity - Making the G since 13.7 billion B.C.
Old 11th June 2015, 09:41 PM   #7
soulmerchant's Avatar
I have them trained to simply tell me if something was damaged. Its far cheaper in the long run and I myself have broken enough things through foolish mistakes.
Then again.. do you have a cat?
Old 12th June 2015, 05:11 PM   #8
Stop blaming everybody! It's a defective tube. It happens!!!!
The stuff you don't know always humbles us.........
Old 12th June 2015, 05:42 PM   #9
Speakerholic
Cal Weldon's Avatar
I'm thinking that little hole near the bottom has something to do with it.
Now we just have to solve the mystery. Who in John's place is the culprit and what was their motive?
hehe
planet10 needs your help:
Let's help Ruth and Dave
Old 12th June 2015, 05:51 PM   #10
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Prob'ly just some tension in the glass made the pin pop - repeated heating-cooling does it's thing....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Amp caused crack phcpbl Tubes / Valves 4 13th January 2014 01:30 AM
Project caused by need tvrgeek Tubes / Valves 10 4th January 2010 09:18 PM
Seeking help- something caused HUGE noise billybudapest Solid State 13 30th December 2007 11:55 AM
Fuzzy vocals caused by box? tade Multi-Way 2 20th March 2006 06:04 PM
What the hell is that ??? nar Pass Labs 21 10th May 2002 06:11 PM
Copyright 1999-2017 diyAudio
