R601P Tube Radio
R601P Tube Radio
Old 4th June 2015, 12:52 AM   #1
drizzle is offline drizzle  Singapore
Default R601P Tube Radio
Hi All,
I have a R601P Tube Radio that works well for about 40mins and then it will distort and goes into humming and scratchy noise, If I switch it off and cool down for a short while it will works again,
Before I go and buy the tube replacement, I would like to have some opinion first. I have ruled out the tuner fault as when I turn to Aux position and listen to my iPod, it did the same thing after 40mins. Potentially it could be the output amp capacitors that is faulty or a faulty tube.
Any advice would be very much appreciated. Below is a review of the R601P that was reviewed by 6Moons. 6moons audio reviews: Quest for Sound R601P tube radio
Old 4th June 2015, 01:12 AM   #2
kevinkr's Avatar
R601P Tube Radio
Why not contact the manufacturer for assistance rather than guessing?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th June 2015, 04:30 AM   #3
Yup did email to the manufacturer but no reply since.
Old 4th June 2015, 08:50 AM   #4
DF96 is offline DF96  England
The pictures suggest it is not a tube radio, but a solid-state radio with (perhaps) a tube output stage. It could sound as bad as any 1950s radio.
The symptoms you describe are consistent with the output valves going into thermal runaway. Possible reasons:
1. poor design, running them too hot
2. gassy valves - these may settle down or may get worse with age
3. leaky coupling capacitor to the valve grid - unlikely in something new (but it is Chinese!)
4. grid leak resistor too high in value
Keep an eye on the valve voltages, especially grid and cathode.
Old 4th June 2015, 11:55 PM   #5
Thanks DF96. Yes, the radio itself is not tube but just the output stage is tube. I have ordered new replacement tube and waiting for it to arrive.
Old 8th January 2016, 03:41 PM   #6
steinboy is offline steinboy
Hi Drizzle,
Did you ever get the issue sorted? Sounds like there's a bad design in the output section. I heard a few other people having the same complaint. Probably the output tube is not properly biased.
R601P Tube RadioHide this!Advertise here!
Old Tube Radio pdavis68 Parts 6 22nd August 2014 06:13 PM
One tube radio felipemuniz Tubes / Valves 3 6th October 2012 09:29 PM
Building a tube radio JECalvert Tubes / Valves 17 16th July 2012 12:12 PM
Help - tube radio JDeV Tubes / Valves 49 19th October 2006 08:18 PM
Another tube radio Magnetmaz Tubes / Valves 7 11th March 2003 06:01 PM
