Bijou resistors specs - diyAudio
Old 26th May 2015, 11:08 PM   #1
weber30 is offline weber30  United States
Default Bijou resistors specs
I looked at the parts for the Bijou amp on
https://www.cavalliaudio.com/diy/bij...?page=ampparts
and was wondering whether the cheaper resistors with around 100ppm (Temperature Coefficient) will do or if they should be 10ppm or at least 50ppm ? Does it really matter with regards to sound/reliability ? Thanks.
Old 27th May 2015, 01:36 AM   #2
astouffer's Avatar
It won't make much difference. You only run into problems in places like opamp feedback loops where a slight change will really show.
Old 27th May 2015, 02:39 AM   #3
HollowState's Avatar
For this circuit 100 ppm or even more is not a problem. And for the most part 1% is not necessary either. Personally I never liked or used ⅛ watt resistors. They're too damn small and hard to work with, meaning fragile. watt is the smallest I use. And metal resistors don't like overloads. But that's another whole discussion.
"The further a society drifts from the truth, the more it will hate those who speak it" ~George Orwell
Old 27th May 2015, 09:22 AM   #4
DF96 is offline DF96  England
Specifying 1/8W resistors for a valve design is daft. At the first DC fault half your resistors go up in smoke; then how do you do fault tracing? 1/4W minimum, but 1/2W would be better.
Temperature coefficient is irrelevant. Almost all modern resistors are much better than those which were routinely used in the valve era.
Old 27th May 2015, 06:12 PM   #5
Default Bijou parts (capacitors)
I'm going through the parts list for the Bijou and it (among others) lists the following two capacitors:
Metalized Polyester/Polypropylene Film 100n 400V
Metalized Polyester/Polypropylene Film 1u 250V
I looked at mouser.com and seem to have difficulty finding the right one (sorry, newbie issue). Anybody got a link?
Does the 400V or 250V refer to AC or DC voltage?
Thanks for the help.
Old 27th May 2015, 06:26 PM   #6
rayma is offline rayma  United States
The marked voltage is always DC (or peak) unless specifically marked AC.
The outer foil is often marked with a line.
Old 27th May 2015, 06:35 PM   #7
SY's Avatar
Film Capacitors | Mouser
There's an embarrassingly large selection.
A philosopher is a blind man in a dark room looking for a black cat that isn't there. A theologian is the man who finds it. - Mencken
Old 28th May 2015, 05:21 PM   #8
I guess you got a good point there. Why safe on a few cents here...
Old 28th May 2015, 05:27 PM   #9
Default Bijou transformer
I am still going through the list of parts for the Bijou amp and started looking at the transformer. It lists the Hammond 270 DAX (117 VAC ; 6.3V at 3.5A) as the recommendation. I read some places, though, that EdCor got some cheaper ones. Anybody know their equivalent (model number) and maybe reasons why using one of those might be a bad idea?
I was also wondering if there is any sound improvement in getting two and running each channel separately (as a mono block, so to say) ?
Old 28th May 2015, 06:34 PM   #10
Edcor makes good transformers for the money. The only problem is they make them when you place your order so for me it is usually about 8 weeks wait time.
I have noticed that you have multiple threads for just this one amplifier. It might be less confusing to people if you had just one thread dedicated to this amplifier. Maybe mods can tidy it up into one thread? Anyway I have had good luck with Edcor transformers.
Bijou schematics question (PINs) weber30 Tubes / Valves 2 26th May 2015 11:11 PM
Cavalli Audio Bijou Completed internals with transformer. jwags818 Swap Meet 0 9th March 2015 08:16 PM
Cavalli Bijou Headphone Amp completed PCB's and Hammond Daz Transformer joefish Swap Meet 3 7th May 2013 06:53 PM
FS: Bijou Headphone Amp huskydawg9 Swap Meet 0 8th May 2010 06:23 PM
Sugden Bijou CD Master TB3 Digital Source 0 16th February 2004 12:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
