Bijou schematics question (PINs) - diyAudio
Old 26th May 2015, 07:20 PM   #1
weber30 is offline weber30  United States
Default Bijou schematics question (PINs)
I am looking at the schematics for the Bijou headphone amp and was wondering if I got this right: V1A and V1B use different pins of the same socket, pins 4,5,9 are reserved for the heater. Am I right or am I getting something wrong here ? See attached pictures.
Old 26th May 2015, 08:21 PM   #2
HollowState's Avatar
You are correct.
"I regard the brain as a computer which will stop working when it's components fail. There is no heaven or afterlife for broken down computers. That is a fairy story for people afraid of the dark." ~Stephen Hawking
Old 26th May 2015, 10:11 PM   #3
Originally Posted by HollowState View Post
You are correct.
Well, lucky me that I got it Thanks.
To convert Novar pins for Magnovale pins Hojvaelde Tubes / Valves 3 28th December 2014 10:49 AM
Question re; Pins 5 & 6 on PCM63 AussiePete Digital Source 0 5th October 2011 08:20 AM
Question re; Pins 5 & 6 on PCM63 AussiePete Digital Source 0 5th October 2011 06:58 AM
TDA7296 Power Supply Pins Question mrfeedback Chip Amps 1 8th April 2011 04:17 PM
FS: Bijou Headphone Amp huskydawg9 Swap Meet 0 8th May 2010 05:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
