| diyAudio Sponsor | ||
Does anyone know how good the output transformer in the Scott LK 72 amp is.
I have a working unit that doesn't sound too great. Can anyone with a revamped LK-72 comment about it's sound ? I guess the caps must be dried up and resistor values gone South in my unit. Thanks. Cheers.
AM |
#2 |
I have an HH Scott 299-C amplifier. The LK-72 is the kit version of the same amplifier.
My amp sounds fantastic! You can get massive amounts of data from this website: www.hhscott.com.
Frank |
#3 |
Thanks Frank.
I will look at the web site. I do have the circuit diagram from an old Glass Audio magazine. My amp has the 7199 driver tube. The tube seem to be working OK - I can't say how good they are. When I got it first and turned it on , the power tubes used to glow with a bluish light on the sides. I turned it off in less than 5 minutes after turning on. The bias was shot . Took a while to read up and find out what has to be done. Now it works but doesn't sound good. Just OK. My Hybrid tube/Mosfet amp sounds far better. Maybe I will restore it and see how it sounds . After that I can decide if I should do a rebuild ( different circuit ) or not. I would however like to keep it as it is - provided it sounds good. Thanks for the info. Cheers. Ashok.
AM |
#4 |
Blue glow is totally normal- its just the glass fluorescing.
Red glow from the large grey anode structure is whats dangerous. Check and replace all coupling caps ( like 0.1uF 600V small caps) and old resistors and it will probably sound great. |
#5 |
Hi ShiFtY,
You are probably right. I should fix it. The unit looks kind of beat up and the bottom looks like a maze with pp wiring . Something that I am not fond of. Yeah I know the purists insist that it is better. It kind of looked daunting changing all the parts - that makes it many many beers away ! I looked at it again a while ago and decided that it was not so bad after all. A couple of hours every day should do it . About the glow. I need to fix my aging brain. I forgot , it WAS a red glow. I remember reading that what happened was bad. I did shut it off quickly and fixed it before turning it on again. Everything seemed to work after that. I just wondered if the tubes could have been shot being 'on' in that condition for about 5 or 10 minutes (max ). I can of course test the tubes. It wasn't a very bright red , just a dull red which came on slowly and I shut it off as soon as I saw it. Thanks. Ashok.
AM |
| Scott LK150 transformer | mageorge | Tubes / Valves | 3 | 10th May 2009 08:44 AM |
| scott 299D output transformers? | iain42 | Tubes / Valves | 11 | 20th February 2009 10:58 PM |
| a thread on Transformer quality | Stefanoo | Pass Labs | 53 | 28th August 2007 05:42 AM |
| HH Scott Transformer #s | Mike K2 | Tubes / Valves | 1 | 22nd March 2007 09:07 AM |
| Power Transformer wanted for Scott LK150 | GlassAudio | Swap Meet | 4 | 30th December 2004 12:40 AM |
| Page generated in 0.07973 seconds (73.24% PHP - 26.76% MySQL) with 10 queries |
