Van Scoyoc SRPP Amp - GvT - diyAudio
Old 3rd February 2004, 10:26 AM   #1
GvTT is offline GvTT  Germany
Default Van Scoyoc SRPP Amp - GvT
having been working quite some time on my new amp project I would like some opinions and ideas on what I came up with. I think this diy-forum will have plenty of experience.
Although I am using a symmetric input signal I have picked the van scoyoc schematic. This gives me the chance to use a non-symmetric signal as input.
This amp is going to be used as a preamplifier, having a maximal input of +/- 1 V and a requested output of +/- 5V.
The output connects to an active filter. there a 13K resistor connects to ground. you can see this one at the output.
To get a more stable output signal I added a tube so the output forms the SRPP scheme. I used +/- 150 to get an output at 0V.
I am really curious for your answers.
Greetings to all
Georg
Old 3rd February 2004, 01:42 PM   #2
Just two quick comments:
1. you can change your input caps to more like 100n and still have excellent low frequency response
2. your OCL zeroing scheme may only partly work. the way you have it, you're changing both outputs at the same time. you will need this control. but, if there are tube mismatchings then you might need to adjust one side separately from the other to get them both at DC zero
Old 3rd February 2004, 01:43 PM   #3
SY's Avatar
I see that you've RC coupled the input, but direct coupled the output. How are you going to control offset?
edit: I see R8 had the same thought.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd February 2004, 02:13 PM   #4
Default Offset correction
The offset-dismatch between the tubes and the common offset are a concern. I don't know how much of a drift during heat-up to expect.
I could imagine using an op-amp and condensator to generate a mean-signal-value and feed this information into the active-filter to compensate the drift. But this means that I have to have a drift of aabout +/- 5V maximum.
I don't know if shifting the whole power-supply with a mosfet for example would be a good idea.
But since I am running it as an active symmetric system (bridged) I am more concerned about the offset between the two chanals.
And if everything fails I can go to a +300/0 V supply and ad the coupling condensators at the output.
I will have to give this offset some more thought.
Thanks for the hints
Georg
Old 3rd February 2004, 03:34 PM   #5
If you're more concerned about the balance and not the absolute value of DC at the output, then you can do this. replace your 2K rheostat with the following:
Old 3rd February 2004, 03:37 PM   #6
Forgot.
I'm not sure how your power amps (or whatever is being driven) will like significant DC current into their input stages.
Also, if you go single polarity supply, then you're input which is also coupled to the SRPP cathode legs will see a high B+.
Old 4th February 2004, 07:33 AM   #7
Smile Offset correction
I tried to work in an active offset correction. But this became so complicated, that I now believe, shifting this whole circuit to +300/0V and using a coupling condensator at the exits will be the best choice.
If you connect the plates of the bottom tubes to ground (in the schematic using symmetric power-supply) the bandwidth is significantly improved, the THD increases to (at least according to the simmulation).
Greetings
Georg
Old 4th February 2004, 10:15 AM   #8
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: Offset correction
So shouldn't you ask yourself why a change in absolute DC voltages (but no change in currents) changes bandwidth and distortion?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
J-fet Zen Srpp ??? Circlomanen Pass Labs 19 11th April 2010 10:27 PM
To SRPP or not? duderduderini Tubes / Valves 2 12th March 2007 04:01 PM
Some questions about Van Scoyoc X-coupled splitter ray_moth Tubes / Valves 2 5th September 2004 10:17 AM
mu / srpp / or CF? AudioGeek Tubes / Valves 9 24th April 2004 06:48 PM
SRPP is....? peranders Tubes / Valves 8 19th December 2003 09:38 PM
Copyright 1999-2017 diyAudio
