Hammond PT and KT88 Design costs.
Old 3rd February 2004, 05:29 AM   #1
Layberinthius is offline Layberinthius  Antarctica
Default Hammond PT and KT88 Design costs.
I was considering using one central PT in this power supply schematic from a 400-0-400 Hammond PT with double the asked-for per-channel current requirements.
Each side asks for 230mA, I intend on using one single 400-0-400 Hammond tranny with 465mA total load.
Would it be possible to keep all components post-tranny in this design the same and just make a central tap for both sides power draw?
The original PSU schematic: http://www.plitron.com/images/Diagrams/vtvkt882a.gif
I have removed the -80v power supply for now so as to simplify the nitty-gritty, I intend on making the -80v supply with a seperate PT later on as all the Hammond transformers have 50v only. not 70v.
Old 3rd February 2004, 06:02 AM   #2
LoL wait a minute, isn't that a dead short across the secondary? :P
Old 3rd February 2004, 06:08 AM   #3
I've had too much sugar this morning
I think I'll scratch this one rather than figure out why I can't do it... and just go along with two psu's in two chassis with two completely seperate components and front-end amplifiers with seperated chassis earths.
Old 3rd February 2004, 06:49 AM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Why not ground the centre tap, then feed each 400v winding end to a separate bridge rectifier?
Old 3rd February 2004, 07:05 AM   #5
Hmm, I'll think about it!
Thanks dhaen
Any hints or ideas is much appreciated.
Old 3rd February 2004, 07:16 AM   #6
No that won't work, now if I done that then both neutral of the rectified side and neutral of AC side would be the same!, Ie complete meltdown.
Old 3rd February 2004, 07:17 AM   #7
Unless I removed the filter caps from ground and placed them on neutral of the rectified side of each channels PSU circuitry.
However I am puzzled as to what will happen with the filament supplys and their associated unmodified 220r and caps, what effect will those see.
Like this:
Old 3rd February 2004, 07:39 AM   #8
dhaen's Avatar
Oops you're right... too early in the morning
Why use a bridge rec at all? Why not just 2 diodes, as the transformer was designed for?
Old 3rd February 2004, 07:40 AM   #9
I don't know how to use only two diodes with a CT PT...
Care to show me? :P
This is one side of the original PSU schematic for comparison:
Old 3rd February 2004, 07:44 AM   #10
dhaen's Avatar
Hammond PT and KT88 Design costs.Hide this!Advertise here!
KT88 and Hammond Transformer Schematics jbldriven Tubes / Valves 80 3rd December 2010 12:47 AM
Hammond 1650P for KT88 PP - any experience? Mario Pankov Tubes / Valves 4 20th December 2008 05:15 PM
