Hi!
I wonder if those speakers are possible to drive with a tube amp (s).
If yes, will you recommend something to build, please.
Evgeny
Evgeny
The imedance curve of these speakers is difficult to drive with tube amps. You might want to consider a more suitable loudspeaker or consider bi-amping with a SS amp driving the low end.
I have heard them powered adequately by one of the Mcintosh push-pull KT88 amps. So, perhaps with a fairly high-wattage push-pull amp or a really powerful SET. OTL using 6AS7 or 6C33C might also be an option. But, like the poster above mentioned, they are not exactly the most tube-friendly speakers.
The spec. sheet tells the tale. The impedance curve requires the speakers be connected to 4 ohm taps. The claimed sensitivity has to be derated to 87 dB.
A H/K Cit. 2 refurbished ala Jim McShane or a pair of Heath W6Ms in good repair will do the job.
Want to DIY? Follow the Heath W6M's footsteps; Williamson topology and Class "AB2" KT88 O/P tubes. While fundamentally sound, the W6M definitely can be improved.
