ground hum issues in an old peak st-100 - diyAudio
Old 28th April 2015, 04:59 AM   #1
Default ground hum issues in an old peak st-100
I have been loving my little Peak St-100 I revived in the thread below, but I am having hum issues and wanted to ask the more experienced among you, where I should start trying to resolve the issue....
help with an old peak st-100single-ended 6GW8
This is the current state of the Peak ST-100. My question is whether I should rebuild the chassis now, or, which I would prefer, try to remove the hum in some way through circuit problems or earth point. I have searched online and find myself pretty confused. This is not really something I know about yet. Is there some simple tips anyone can give me for beginning to eliminate the hum?
The earth point is here - too much? too much chaos?!?
....any help would be greatly appreciated....
I am pretty new to all this, though I have also also built a modified kit 2A3 SE making a ridiculous copper chassis for it (the copper was lying around and I am a metalworker and TIG welding is fun....) But somehow I still love the uncluttered sound of the old Peak, even though it has no power.... I just want to make it better. and better.... : )
Sean.
Old 28th April 2015, 01:09 PM   #2
MelB is offline MelB  Canada
Would appear your 6.3v supply is floating. Does the 6.3v supply have a center tap? If not the first thing to do is get two 100 to 220 ohm resistors and add one from 6GW8 pin 4 to ground and one from 6GW8 pin 5 to ground. (The resistors should be of the same value) You just need to do that on one of the 6GW8 tubes. I would also remove those 6.3v wires from pin 4 and pin 5 and twist them together before re-attaching them while you are at it.
There is a nice example of a twisted wire on your 2A3 amp near the top.
Old 28th April 2015, 02:09 PM   #3
DF96 is offline DF96  England
The first thing to do (if necessary - the photos are not entirely clear) is to remove the transformer CT connection from the 'star' point and instead wire it to the reservoir cap negative terminal.
Is that really an 820R 'bleeder' resistor? More like a room heater!
A circuit digram would help. You have given us a (sort of) wiring diagram, but azlmost certainly it does not show exactly where the grounds go.
Old 28th April 2015, 04:56 PM   #4
azazello's Avatar
If You connect el. cap 350-470 uF in point A to ground, humm will decrease.
I don't like Your filter group....I prefer CLC / 20uF, 10 Hn, 350-470 uF/ group after rectifier and connect p.A to 470 uF.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 29th April 2015, 03:02 AM   #5
Thankyou all SO MUCH for responding.
I am going through these points now and writing as I go....
azazello - you are dead right there - I will get a cap for this - I have no HV caps here except for a 30uF, but i tried that and it made a huge difference.... And can you tell me what you mean by the filter group? I am pretty new to all this, so any pointers, or links you can send me would be great....
DF96 - I connected CT to negative of reservoir cap - you were right - it was straight to ground point. Yes - that resistor was here in my box and I used it. : ) Will make up another circuit diagram soon too!
MelB - The centre tap of the transformer is hard wired to one side of the heater supplies, so that does go to ground. I disconnected the heater wires and twisted them as you described....
When I put in the cap that azazello suggests I will report back.
Cheers.
Old 29th April 2015, 09:01 AM   #6
I now realise that it is the supply rail feed. I was thrown off course by the peculiar drawing convention.
Old 29th April 2015, 09:30 AM   #7
sorry - the drawing is awful i guess - this is not my field at all! i am pretty dumb with all this - not knowing what a bleeder resistor is or the like - so i have been looking up lots of stuff, learning a little, like CLC circuit for power, etc....
lots to learn!
Old 29th April 2015, 12:38 PM   #8
azazello's Avatar
Filter circuits - Inductor Filter, LC filter, CLC or PI filter, Capacitor filter
Cs are caps 20-40 uF and 470 uF, L is iron chock about 10 Hn /from Hammond or EdcorUSA/
Old 30th April 2015, 04:21 AM   #9
thanks azazello - i am in australia, getting a choke mailed as there isn't much around i can find cheap.... then will make and report back....
thanks for your time and knowledge - much appreciated!
AKSA 100 N+ the hum the hum! Erskib AKSA 18 10th February 2015 02:03 AM
B&K ST-202+ hum ds307 Solid State 0 5th May 2014 10:09 PM
help with an old Peak ST-100 - single ended 6GW8 orangealpaca Tubes / Valves 28 21st February 2014 07:52 AM
Should I ground my ST 70? richamor Tubes / Valves 10 23rd March 2012 06:45 AM
Bedini 100/100 Hum in one channel. UberRyan Solid State 3 14th April 2010 06:28 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
