Volume control chip - diyAudio
Old 20th April 2015, 01:00 PM   #1
Default Volume control chip
Does anyone know what the
".. the Signature II has a 117-step, chip-based differential volume control, "
used in this insanely overpriced, vcr lookin preamp is?
VTL TL-5.5 Series II Signature line preamplifier | Stereophile.com
thanks
Old 20th April 2015, 03:54 PM   #2
I just used this with very good results: http://www.mouser.com/ds/2/405/sbos218a-125896.pdf
It has 254 steps I think, -95.5db to +31.5db, with .5db steps.
Old 20th April 2015, 04:13 PM   #3
thanks! supposedly the one in the VTL doesn't have any op-amps in it and I was just curious to look at the datasheet and see how that could be.
passive volume control for audiosector chip amp JonGain Chip Amps 3 1st December 2014 04:15 AM
Cheap volume control chip nightanole Analog Line Level 3 9th January 2011 11:53 PM
adding volume control to my chip amp darkczar Chip Amps 12 5th October 2010 12:27 PM
how is the quality of a chip-based volume control VS normal stepped attenuator? jarthel Parts 4 16th July 2007 02:40 PM
Proximity of volume control to chip in IGC Nuuk Chip Amps 22 25th July 2003 07:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
