Strange problem wit a 3 tube preamplifier - diyAudio
Old 18th April 2015, 07:49 AM   #1
Default Strange problem wit a 3 tube preamplifier
Hi
I had a strange experience with two of my TPA3116 boards this evening. I tried one board with a 3 tube pre that I use to listen last year just to compare the sound with another one. As soon as i power on the amplifier it start with a strong an repetitive pop in right speaker only. I immediately disconnected the pre an power on the amplifier again. Unfortunately it continue with this behavior only. Doing once again with a new board (curiosity killed the cat and I received the same result. The pre use to be in a good condition until now but now obviously is not working and killed my boards.
Any idea how to fix first the boards and then the pre?
The preamp is like this:
6N3 bile rectifier tube preamp streaking version ( with transformer )-in Home Appliances Stocks from Home Appliances on Aliexpress.com | Alibaba Group
but with R-core transformer. Where to look first for the "guilty" one?
Thank you!
Click the image to open in full size. Click the image to open in full size.
Old 19th April 2015, 02:12 PM   #2
When I got popping in my headphone amp it was a resistor going bad. I could see a spark come from it every time there was a pop.
Old 23rd April 2015, 11:45 PM   #3
Solved.
After trying to improved it with a new ALPS pot something was done unclean with the wiring and I think that was the reason for the preamp to start oscillate and damaged the amplifier module.
After re-work all the wiring and measure everything now it works perfect.
Thank you!
Very Strange Problem with DIY Phono Stage (Possible Load Problem?) steve516 Analogue Source 9 26th February 2014 08:06 AM
Help wit hk 3490 Matei Alin Solid State 0 6th November 2011 04:00 PM
Strange problem with Grundig CS200 tube receiver Rodeodave Tubes / Valves 16 15th June 2011 03:21 PM
Strange Problem In Tube Amp Build nogoodnamesleft Tubes / Valves 19 26th January 2011 02:28 PM
Strange preamplifier output stage Groundloops Solid State 5 21st December 2007 01:54 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
