Fully silver hard wired
Old 3rd February 2004, 12:16 AM   #41
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
In the description they say the 2% content is easily enough to prevent silver leaching. Are 4% solders a lot more?
I have been using eutectic solder from RS containing 4% silver for at least a decade...Probably more.
26 Quid a spool will depend on the weight of the spool, won't it?
No matter the price, it's excellent for soldering silver.
P.S. Jeweller silver is only appropiate for Magura's application where you need contact hardness...Other than that, forget it.
Frank
Old 3rd February 2004, 01:59 AM   #42
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Has anyone considered...
Perhaps the reason that silver is popular has nothing to do with its slightly improved conductivity compared to solder, but the fact that you get far better soldered joints?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 3rd February 2004, 02:05 AM   #43
fdegrove's Avatar
Default Jaws' Still Out There..
Perhaps the reason that silver is popular has nothing to do with its slightly improved conductivity compared to solder, but the fact that you get far better soldered joints.
Nope....
Believe or not, I don't care either way but it's soo revealing of faults downstream or upstream the chain that this is definetely a tool/product I just don't want to be without...
Try it it out for yourself, please do. It can be a true ear opener...
Frank
Old 3rd February 2004, 09:10 AM   #44
eeka chu is offline eeka chu  United Kingdom
Thanks FDE,
I was only thinking of the jeweller's silver for Magura, don't worry.
Do you have an RS P/N for the silver solder? They sure do have a lot listed there! The 26 pounds was for a 500g spool I think, RS 551-671. I've always used standard tin / lead solder so I wasn't quite sure about the prices.
Is this the kind? 362-8061
Thanks,
John
Old 3rd February 2004, 10:31 AM   #45
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by eeka chu
Magura,
What make - model of machining centre do you have out of interest?
A Bridgeport VMC 1000XP, A Daewoo HM630 and a number of others i cant remeber the type of by heart...and naturally a bunch of CNC lathes
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 3rd February 2004, 11:00 AM   #46
Looks like I'll have to move to Denmark!
Do you have these at your house? They look like some seriously expensive tools. I thought I saw the BP close $100,000 new. I imagine tooling is not a fun job either.
I found a video clip of the Daewoo centre running and remembered using an old manual BP to machine something. I had to take off about half a mm per pass before it began oscillating. The Daewoo seems to be slicing thru the metal.
Very impress stuff!
I'm still stuck using a Denford Orac CNC lathe.
It's small enough that I'm even considering dragging it into the house so I can wind coils in the warm.
John
Fully silver hard wiredHide this!Advertise here!
Ill be getting wired here now... phluffy Introductions 2 4th May 2009 04:42 PM
FS: Squeezebox 2 (wired) loddie Swap Meet 0 8th January 2008 04:22 AM
is this wired right? shooto Instruments and Amps 1 17th July 2006 03:47 AM
what size amp for DPL 12 wired for 4 ohm? crippledchicken Subwoofers 7 20th January 2005 12:10 AM
Machining (was fully silver wired) Magura Everything Else 8 13th February 2004 01:36 AM
