The heater is at 5v 3amp which i've matched to a T.
I can see some heater flakes inside the tube moving around so there is a chance of causing 'real' heater to plate shorting and while fired up I managed to peek inside the plate envelope (rather long) and see some areas where the flake has supposedly fallen off... almost as if someone took a knife to a hot piece of metal. I guess my main question is will I see any negative effects during high-voltage operation? I get a reading of 3v across heater and plate with my multimeter. Cheers. |
#2 | |
diyAudio Senior Member
If it's really metal, junk the tube and get over it. Sorry for being blunt, but try another 5AS4 to be sure... Don't get paranoid over this, tubes are dammed tough beasts... Cheers,
Frank |
#3 |
Ok then :P
| Full wave or half wave rectification help! | HaLo6 | Digital Line Level | 1 | 26th March 2009 01:14 AM |
| Full Wave Rectifier | dscrobe | Tubes / Valves | 6 | 1st July 2008 07:35 PM |
| Full wave vs full wave bridge rectifier | jeff mai | Parts | 31 | 11th February 2005 11:43 PM |
