Sansui AU70 - diyAudio
Old 12th April 2015, 05:11 PM   #1
mr2racer's Avatar
Default Sansui AU70
Hey Everyone, hope your Sunday is going as nicely as mine!
I have a couple of questions about the Sansui AU70 output transformer. I've noticed they connect the cathodes to the opposite ends of the output transformer secondary. I'm assuming they are using the resistance of the windings to act as a cathode bias resistor? While at the same time using the connection for feedback? But somehow having DC in the secondary seems like a bad idea? Also, the 410 volt B+ seems really high even if you had good vintage 7189's.
So the real question is this, if I went with a standard cathode resistor and a more standard feedback arrangement would the resulting amp suffer sonically? All other things being equal of course.
Kevin
Artificial intelligence is no match for natural stupidity- Red Green
Old 12th April 2015, 05:25 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Half of the circuit is missing here. As I recall from memory. there is -ve DC bias on the grids from a supply line and the cathodes use the windings in the cathodes as positive feedback and current mirror. The greater the load on the transformer the more +ve feedback to improve the loudspeaker imperfections.
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 12th April 2015, 06:01 PM   #3
Look at the whole schematic. A bias supply is present. The O/P "iron" secondary is grounded via a tap, not an end. It appears that Sansui was using those secondaries for local cathode negative feedback, not bias. It's most unlikely that the engineers did not account for flux balance in the core.
Leave the circuit topology be, except for rewiring the O/P tube sockets to 7189 specifications. Stock of 7189A tubes is NOT available, at anything resembling a rational price. Properly matched pairs of 7189As are wishful thinking.
Install Russian 6П14П-EB (6p14p-ev), AKA EL84M, O/P tubes and you'll be fine. The Russian "firebottles" are genuine 7189 equivalents, which are VERY tough and good sounding too boot. To maximize O/P tube service life, set the "idle" current a tad lower than Sansui's doc. suggests.
Eli D.
Old 13th April 2015, 03:08 AM   #4
mr2racer's Avatar
Thanks guys, I see the bias connection now. If you look at the partial schematic in my jpeg there are two connections; C3 and C4 for individual bias. The schematic that Eli posted shows the outputs biased as a matched pair.
sansui AU2900 Carlosraj Solid State 4 18th November 2013 10:45 AM
Sansui help please? cross reference Solid State 22 4th September 2012 06:21 AM
sansui 9090 millertyms Construction Tips 0 7th November 2009 09:16 AM
help with Sansui BA5000 bblock1970 Solid State 5 10th September 2004 08:35 PM
SANSUI -G4500 sonicgrail Everything Else 0 11th November 2001 05:46 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
