KT120 x 4 / 240W Push Pull TUBE AMP MONOBLOCKS - diyAudio
Old 11th April 2015, 04:28 PM   #1
Default KT120 x 4 / 240W Push Pull TUBE AMP MONOBLOCKS
Has anyone of you dear members built the 4 x KT120, 240W push-pull tube power amp, designed and described in details by Mr. Gerhard Haas in an article issued in the November 2014 volume of AudioXpress audio magazine?
I have not been able to find the suitable output and power transformers as the PMZ 135/50 transformer core material seems to be unavailable from the supplier. See the photo attached showing the table with transformer specifications in the artice. Any help from your side ?
Old 11th April 2015, 05:53 PM   #2
Zibi is offline Zibi  Poland
PMZ135 | eBay
Old 11th April 2015, 06:36 PM   #3
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
For the Output transformer a Hammond 1650W seems suitable. 1,9K and 4,8,16 ohm taps, whit a 8 ohm speaker on the 4 ohm tap you should be all set.
As for the power transformer, Industrial transformers that supply 480VAC are common, you'l only need a 6V heater transformer and a little 120v transformer for bias (I would opt to stabilize the bias voltage)
813 push-pull output 250W tube amp liangw Tubes / Valves 43 28th November 2013 02:12 AM
Push Pull 6HJ5 Monoblocks nic6paul Tubes / Valves 5 15th November 2013 03:03 AM
Ultra Linear Push Pull Tube amp Hoej Tubes / Valves 54 18th March 2011 12:46 AM
Minimum space between 6V6 tube in Push-Pull Amp brucetassin Tubes / Valves 34 14th January 2011 02:37 AM
Fender push pull amp... using one tube only.. is it dangerous? akimball442 Tubes / Valves 2 3rd March 2007 05:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
