Mounting output tran and filter choke together - diyAudio
Old 1st April 2015, 01:36 AM   #1
Default Mounting output tran and filter choke together
I'm finally building the "sit on a shelf and use" version of an amp I've been toying around with for a couple of months. While looking at how to layout the chassis I noticed that the power filter chokes and the output transformers have the same mounting hole spacing. This means I could mount them on the top and bottom of the aluminum chassis as show in the picture, saving a couple of screw holes and using the available space better. Is there any kind of interference that could occur here? It seem unlikely to me, but I figured I should ask.
As always, thanks....
Old 1st April 2015, 01:45 AM   #2
rayma is offline rayma  United States
Yes, Dynaco did something like this in the Stereo 70, but that channel always had a little more hum than the other one.
Maybe if the chassis is thick steel, or if an extra steel plate is under the choke.
Old 1st April 2015, 01:47 AM   #3
Can work, that is exactly how my Bottlehead S.E.X amp is laid out.
Old 1st April 2015, 05:13 PM   #4
azazello's Avatar
It's leading to LowEnd, but not to HiEnd....
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Filter Choke Question Tuberguy Power Supplies 1 15th March 2014 11:09 AM
Marantz 9 Filter CHOKE value?? bear Tubes / Valves 4 24th February 2010 03:26 AM
Choke Input Filter. G Tubes / Valves 8 11th February 2008 09:57 PM
Filter Choke BC Parts 2 22nd September 2004 10:36 PM
humbucking filter choke - how different? zobsky Tubes / Valves 4 19th October 2003 10:23 PM
Copyright 1999-2017 diyAudio
