I could lose some heat - suggestions? - Page 2 - diyAudio
Old 1st February 2004, 01:20 PM   #11
Sjef is offline Sjef  Netherlands
Do you have the possiblity to measure the temperature inside the box ? For us Humans a temperature of about 40 degrees Celcius feels kinda hot, for electronics however this is a piece of cake to handle.
Old 1st February 2004, 01:56 PM   #12
7V is offline 7V  United Kingdom
7V's Avatar
Hmmm, could be tricky. If I had the hole in the cabinet to insert the thermometer, there may not be an issue in the first place. I could detach one of the wooden side panels and stick in a thermometer but this act, in itself, would probably cool things down.
We could just be talking of a piece of cake anyway. My concern is simply because I had one breakdown - tube heater regulator overheating - but fitting a better heatsink to this component could have solved the problem anyway. The designer is of that view.
Did you lose a case of CD's at RMAF? Jon Ver Halen Pass Labs 0 20th October 2008 03:34 PM
Help: Need to lose some volts Decker Chip Amps 15 7th October 2005 08:47 AM
How much flux do you lose if... 454Casull Multi-Way 11 18th January 2005 10:05 PM
Do I lose power when parafeeding? Bas Horneman Tubes / Valves 2 26th March 2004 03:30 PM
Copyright 1999-2017 diyAudio
