Question on Tube Rectifier..help please. - diyAudio
Old 21st March 2015, 12:29 AM   #1
Default Question on Tube Rectifier..help please.
will a tube rectifier pass dc ....ie i would like to pass output from a full wave bridge thro a 6x4/ex90. Will it work ? Please dont respond with why.
thanks ever so much in advance
bill
Old 21st March 2015, 12:41 AM   #2
kevinkr's Avatar
Yes
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 21st March 2015, 12:58 AM   #3
rayma is offline rayma  United States
That's what they do, and this is fine for a soft start, but the filament still must be referred to the cathode.
Old 21st March 2015, 01:03 AM   #4
kevinkr's Avatar
@ Rayma the 6X4 is indirectly heated and does not need a cathode to filament connection. (Designed for large positive cathode to filament differential) It was commonly used in applications where the filament supply was common with other 6.3V filaments. (Like tuners, small pre-amps and very small amps)
@Studioplex I hope this helps. Wire as you proposed.
Old 21st March 2015, 01:09 AM   #5
Yes, I remember now that's indeed the case.
Old 21st March 2015, 04:19 AM   #6
ok thanks I need more voltage than i would get half wave so though full wave bridge into the tube rectifier would raise just put positive on both anodes. I want the sag. etc
thanks guys
Old 21st March 2015, 05:46 AM   #7
thanks guys
So, you are bridge rectifying an untapped winding. There is no need to use both a 4 SS diode bridge and the vacuum rectifier. Construct a hybrid bridge, with 2X UF4007s forming the connection to ground and the tube forming the connection to the B+ filter.
Eli D.
Old 21st March 2015, 12:09 PM   #8
soulmerchant's Avatar
google Graetz bridge.
Question regarding rectifier tube replacement platinum95 Tubes / Valves 3 10th November 2012 02:59 PM
tube rectifier question chopchip Tubes / Valves 3 6th June 2010 12:37 PM
Tube rectifier question. el rockyo Tubes / Valves 7 27th March 2010 08:57 AM
5Z4P rectifier tube question Original Burnedfingers Tubes / Valves 3 7th September 2006 12:58 AM
rectifier tube question jtsjf Tubes / Valves 3 11th April 2004 07:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
