SE output transformer
Old 19th March 2015, 08:30 PM   #1
famousmockingbird is offline famousmockingbird  United States
Default SE output transformer
I know I have read about this being discussed but can't find the exact thread.
Are these two transformers the same?
https://www.edcorusa.com/gxse10-16-5k
https://www.edcorusa.com/gxse10-8-2_5k
If the impedance ratio is just a a squared function of the turns ratio these two transformers are the same. BUT somewhere in my soggy brain there is a voice telling me that if I try and use the gxse10-16-5k with an 8 ohm load giving me a primary impedance of 2.5k the primary inductance will be less then what I expect?
Are these the same transformers with different stickers? Or are they different? The reason I just don't order the gxse10-8-2_5k? Because I can purchase the gxse10-16-5k and have them in a week as appose to two months.
Edit: I plan to use them with some Tubelab SE boards. I see he has on his site that he has tried the xse15-8-5k, the gxse line has better low end performance.
-bird
Old 19th March 2015, 08:42 PM   #2
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
They are slightly different (see max current spec.) Chances are for many applications they can be used interchangeably.
Old 19th March 2015, 08:53 PM   #3
Thank you for the quick response.
I see that now, for the gxse-8-2_5k they give the spec of 6H for primary inductance, 149 ohm DCR, and 120mA current for rated performance. The gxse-16-5k they only tell you 80mA for the rated performance. Good catch
Old 19th March 2015, 09:33 PM   #4
I forgot to mention I want to use them for the Tubelab SE. Any advice? Has anyone used Edcor for these amps? They will be paired with Klipsch Cornwall's most likely.
Old 19th March 2015, 11:04 PM   #5
musical noise is offline musical noise  Switzerland
While the reflected impedance between those two OPT's will be the same, the 5K unit will present a higher inductance on the primary at the low end. Given that the K-33 woofer in the Cornwall is nominally a 4 Ohm driver, the amp will have a very low damping factor even in the context of an SET amp. If I were you, I'd probably be looking at the 15W Edcor units at the 3.5K or even 5K:8 impedance ratios. The slightly lower max power to be had with the higher impedance OPT's will more than be offset by the lower distortion and better damping.
https://www.edcorusa.com/gxse15-8-3_5k
https://www.edcorusa.com/gxse15-8-5k
The additional $20 per pair for these bigger OPT's pales in comparison to the cost of the 300B tubes that you will be buying for this amp. Just MHO.
Old 20th March 2015, 07:42 PM   #6
316a is offline 316a  England
316a's Avatar
Is this for a 5k transformer ? If so then there may be very limited output under 100Hz . 149 ohms for such a small transformer indicates not many turns . The rule of thumb I use is 20H per 1K of Ra of the driving valve in triode SE . If you want to use midbass and up , probably fine . Hope this helps
316a
Old 20th March 2015, 08:33 PM   #7
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I used both the GXSE15-8-5K and GXSE15-8-3.5K as output transformers for 6P41S SE amps, and have been quite pleased with both transformers.
If there are no dogs in Heaven, I don't want to go there.
Old 21st March 2015, 12:20 AM   #8
Unfortunately I did not win the auction. The pair went for $15 more then what they go for brand new.
It's probably for the best, I have been looking at Transcendar, the prices seem more then fair to me and the specs look really good.
What can be expected from a current production 300b in class A2? I have zero experience with DHT.
Old 21st March 2015, 12:42 AM   #9
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
have you considered electraprint?
Electra-Print.com Audio Transformers
http://www.evancotler.com
Old 21st March 2015, 01:24 AM   #10
kevinkr's Avatar
Electra-print and Lundahl would both be good choices.. I've also had pretty good results from modestly priced Transcendars which seem to offer great value for the performance offered.
Note that the 300B is not really intended for class A2 operation. (I have designed and built a significant number of both PP and SE 300B amps over the years..)
8 - 10Wrms is possible with good tube life.. If you really want to push them and bend the rules by running them into A2 you can get 16W or so out of a single tube.. I've not done this, and I hear tube life is quite short even with genuine WE 300B.. (There was a Japanese 300B SE amp rated at 17W per channel from a single 300B per channel!)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
SE output transformerHide this!Advertise here!
Hashimoto SE Output Transformer dr._sleep Tubes / Valves 29 16th January 2014 01:24 PM
SE Output Transformer question jimmy74 Tubes / Valves 3 2nd August 2013 12:36 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 06:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Output transformer (SE) - DIY pwan Tubes / Valves 3 17th June 2007 06:03 PM
