Madison Fielding Rcvr -- Filament Trick - diyAudio
Old 19th March 2015, 03:01 PM   #1
jackinnj's Avatar
Default Madison Fielding Rcvr -- Filament Trick
I have had this Madison Fielding 440 Receiver forever -- and found one at a thrift operation. It was manufactured by Crosby circa 1961. It is interesting that they run the filaments for the preamp section through the cathodes of the output stage which is set at 24V. I can't imagine that this is a bit below optimal for the ECC83/12AX7 input tubes:
Old 19th March 2015, 03:56 PM   #2
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
I'm lost where is the 24V connection for the preamp tubes?
Perhaps I'm missing something..WX..
I see what looks like a fixed bias supply?
M. Gregg
What is the sound of one hand clapping?
Old 19th March 2015, 04:01 PM   #3
20to20 is offline 20to20  United States
20to20's Avatar
M. Gregg
The heaters become the cathode resistors when hot. Then they pick off 12v. to feed back up to the grids to create the 12v. bias needed for the outputs.
20
Old 19th March 2015, 04:13 PM   #4
M Gregg's Avatar
20
Thank's
OK got it..
Bit of a pig when the output stage fails but its really a preamp heater..LOL
M. Gregg
Old 19th March 2015, 05:53 PM   #5
jackinnj's Avatar
I wonder if they ever considered that this would modulate the heaters of the preamp stage!
Old 19th March 2015, 06:45 PM   #6
20to20's Avatar
The heaters are only about 80 ohms to ground when hot. And that is behind the 420K grid leak where the grid signal is. There is no concern about signal crossovers to anything. They would act like any other cathode resistor and provide a small degenerative feedback. They didn't even bother to bypass them which could have easily been done.
20
Old 19th March 2015, 08:38 PM   #7
gofar99 is offline gofar99  United States
Eico did that in their dual 35 WPC power amps. Ran 112AX7s in the cathodes of the EL34s. They did have rather large filter caps across the heaters though. A simple way to get DC heaters without a separate supply. I am sure other companies did the same.
Good Listening
Bruce
Old 19th March 2015, 09:41 PM   #8
20to20's Avatar
A Silvertone model 29 P-P 6BQ5 uses 1 12AX7 and a 10R in series w/ a 50uf bypass. It has 15v. on the K dropped through the R. It puts the hot heater at 90R if it's carrying the whole 150ma.
Old 19th March 2015, 10:01 PM   #9
SpreadSpectrum's Avatar
My Fisher X-101-B used the heaters for four 12AX7s as the cathode resistor of the output tubes.
I modified the amp to have four individual bypassed current regulators as cathode resistors because I kept having 7591s red plate due to less than perfect matching. Now they are all happy. I don't like designs that damage tubes if they aren't perfectly matched.
My Blog: http://tubeswithatwist.blogspot.com/
Old 21st March 2015, 12:51 AM   #10
kevinkr's Avatar
The HH Scott 99 mono integrated amplifier used the same scheme and might have been one of the first to do so back around 1954..
"Extraordinary claims require extraordinary evidence." - Carl Sagan
FS: SACD Players (Yamaha S1800BL, Denon 1930CI, Sony S9000ES) and Onkyo TX-SR508 Rcvr zxgravediggerxz Swap Meet 9 17th December 2012 06:44 AM
Lightbulb trick on filament circuit? Rundmaus Tubes / Valves 9 24th January 2011 03:31 PM
Tube mod a HT rcvr? mashaffer Tubes / Valves 7 4th February 2008 01:21 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
Pioneer rcvr/eros Q bbksv Multi-Way 1 14th December 2003 07:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
