white follower for driving mosfets.
Old 18th March 2015, 07:03 PM   #1
kees52 is offline kees52  Netherlands
Default white follower for driving mosfets.
Hi all
What will happen if a white follower drives mosfets in dc form, I have done this with my amp, first a normal cathode follower with tube current source but i think the sound is better with the white follower, more sweet without losing details.
I have a question about the upper tube who is driven bij de voltage amp the grid resistors I am not shure what to do, I have now 12 volts on upper tube, also keep in mind that the balancing is such that the output offset is low a servo do keep this in track, tubes are not such stable things.
I have put in part of schematic to let you see what i mean, with a single voltage I see a divider in the grid of upper tube, it has 20mA idle current.
Maybe it is idea to put two resistors over the current potmeter of the fets to ground what make the white follower see better load? Mosfet capacitances are not really a liniair factor, that is what needs current but impedance is still high, follower is low.
regards
kees
white follower for driving mosfets.Hide this!Advertise here!
White Cathode Follower Quandary maynard999 Tubes / Valves 30 2nd December 2014 04:13 AM
very low impedance white follower with 6H13C kees52 Tubes / Valves 0 20th December 2011 03:07 PM
DC coupled cathode follower driving me nuts funk1980 Tubes / Valves 12 9th November 2011 05:48 PM
dissimilar triode for White cathode follower? needtubes Tubes / Valves 6 11th March 2005 01:30 AM
Driving a MOSFET power follower RichardJones Pass Labs 19 22nd July 2002 02:02 PM
