Distance between two audio input valves - diyAudio
Old 18th March 2015, 01:35 PM   #1
apnneto is offline apnneto  Brazil
Default Distance between two audio input valves
What is the shortest distance between two audio input valves? My concern in this new layout is to avoid crosstalk.
I am using the input stage 12AX7 tube and the inverter is the 12AT7 tube. I want to make the holes in the chassis, but need this information to avoid future problems.
This is a stereo amplifier, so the question is about the distance between the tube in the two channels and not between the tubes of the same channel.
Regards.
Old 18th March 2015, 01:55 PM   #2
rayma is offline rayma  United States
The wiring and/or the pcb layout will contribute much more to crosstalk than any coupling between two different tube envelopes.
Old 18th March 2015, 02:13 PM   #3
Okay. Thanky you rayma.
My case is as follows: the two channels are completely independent, only sharing the ground star. When I touch the coupling capacitor of one of the channels, the crosstalk disappears. If I use sockets with shields also crosstalk disappears. The distance between the inlet tubes of each channel is 10cm. I wonder where the problem lies?
Old 18th March 2015, 02:14 PM   #4
Could be the coupling caps themselves. Some people have used shields over large caps to prevent coupling from the outer foil to other parts of the circuit.
It is possible to have coupling between the plate structures of the two tubes envelopes if they are very close. It's odd that either installing
a shield OR touching the cap will kill the crosstalk, though.
Old 18th March 2015, 02:29 PM   #5
I tried to use capacitors of different brands and types but behavior was the same.
Below is a photo of the plate. The distance between the paths of audio signals is 1 mm, being in parallel. I tried to connect directly from the ECC 83 socket to the KT88, but without effect.
I am developing this board only for learning. For this reason I would check what is going to be able to learn and redo the layout.
Old 18th March 2015, 02:35 PM   #6
I would add at least an inch of space between the two channels, or make two separate, identical boards, mounted some distance apart.
Old 18th March 2015, 02:43 PM   #7
Ok. I'll split the plate in half and find what the distance that the problem disappears. After post here my findings. Grateful for the support.
Old 18th March 2015, 02:45 PM   #8
Yes, the channels are rather close together, and capacitive coupling is certain. A shield strip between the channels could help as well.
Old 18th March 2015, 05:04 PM   #9
artosalo's Avatar
...My concern in this new layout is to avoid crosstalk...This is a stereo amplifier...
Then the crosstalk does not need to be more than some 35...40 dB.
If you look the crosstalk specification of top quality MC cartridges, it's something
between 20 to 30 dB.
http://ortofon.com/images/hifi/broch...5_brochure.pdf
Old 18th March 2015, 05:16 PM   #10
Originally Posted by artosalo View Post
Then the crosstalk does not need to be more than some 35...40 dB. If you look the crosstalk specification of top quality MC cartridges, it's something
Cross coupling on a pcb is quite different from that in a phono cartridge, and cannot be compared in that way.
Best make of audio valves/tubes payitforwardeddie Tubes / Valves 21 20th March 2011 05:58 PM
What type of audio transformers to use for tubes / valves sco1t Tubes / Valves 16 5th April 2010 12:22 AM
What distance should a toroidal be from the audio circuit? gaplessophile Chip Amps 152 10th May 2006 03:50 PM
Different input valves for KT88 kianbach Tubes / Valves 1 19th April 2005 07:10 PM
X-mission of audio over 2.5kms distance Samuel Jayaraj Everything Else 8 6th January 2005 11:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
