Series Caps on Power Supply - diyAudio
Old 17th March 2015, 10:39 PM   #1
cogitech's Avatar
Default Series Caps on Power Supply
I'm once again considering a tubelab SSE. The power supply cap requirements have got me thinking about voltage distribution amongst capacitors in series. I do not have any 500v parts laying around, but I do have some fairly good caps of lower voltage.
Am I correct in thinking that (for example) two 250v caps in series will satisfy the requirements of a single 500v power supply cap?
(Yes, I do realize that the overall capacitance will drop)
Old 17th March 2015, 10:44 PM   #2
cerrem is offline cerrem  United States
Yes.... that is correct.... Just be carefull to use similair values to keep the capacitive voltage divider with shared voltage....
If you have +/- 10 % caps ..... then consider the Worse Case ...then make sure to account for % 20% capacitance delta between the caps with respect to applied DC voltage + a little headroom of course...
Old 17th March 2015, 10:47 PM   #3
rayma is online now rayma  United States
It's also necessary to use a resistive divider of (for example) 100k across each cap to ensure voltage balancing.
You cannot rely on the capacitance values for balancing the voltages.
Old 17th March 2015, 10:53 PM   #4
There's a good diagram of the needed resistor setup at:
Rap on Replacing Electrolytic Capacitors
and it's important, I've blown up capacitors by neglecting this.
Old 17th March 2015, 10:56 PM   #5
Yes, you will. The resistors must be low enough in value to swamp the capacitor leakage current, so allow a bleeder current of several mA.
Old 17th March 2015, 11:33 PM   #6
cogitech's Avatar
Thanks everyone. Awesome info!
Series Shunt regulated power supply?? Tubenstein Power Supplies 0 11th January 2014 03:03 PM
Series power amp supply karellen Power Supplies 4 20th January 2013 12:43 PM
Series power amps using a floating power supply rtarbell Solid State 6 25th February 2006 09:18 PM
power supply: shunt or series?? AudioGeek Solid State 34 25th July 2004 03:02 AM
Series Caps in Power supply Jonathan M Solid State 14 11th April 2003 07:49 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
