Most expensive parts in DIY tube amp - diyAudio
Old 17th March 2015, 06:12 PM   #1
Default Most expensive parts in DIY tube amp
I've been thinking about doing a basic single-ended amp design as a first amp build. Something similar to this...
http://www.bonavolta.ch/hobby/en/audio/kt88.htm
But when I looked up output transformers they're 2-300 dollars for each, which would be 4-600 dollars for a stereo amp just in output transformers...My jaw just about dropped to the ground with that...Am I right? For an amp somewhere around 10WPC its gonna cost 500 bucks in output transformers? Or am I missing something... And also what are the other main expensive parts? I've assumed of course the tubes, which I'm guessing would be about $100 total for a stereo amp, the power supply transformer and inductor which I also didn't expect to top $100. And then besides that its mostly the case and miscellaneous resistors and capacitors etc. right?
But those damn output transformers...are they really that expensive?
Old 17th March 2015, 06:31 PM   #2
20to20 is offline 20to20  United States
20to20's Avatar
You have a lot of researching to do before you decide on doing this project.
Old 17th March 2015, 06:48 PM   #3
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
It all depends,
What are you trying to create?..yes I know its a SE amp however there are SE amps and SE amps..you can build to a budget.
Have you looked at the Edcor site?
There are SE output Tx's and output Tx's..what I'm saying is: If you build with Tango etc expect to pay..there are higher prices you could build with Audio note silver wound transformers which are ridiculous money..its a trade off..
This is just an example:
https://edcorusa.com/gxse15-8-2_5k
M. Gregg
What is the sound of one hand clapping?
Old 17th March 2015, 06:58 PM   #4
Everyone wants to build a single ended amp at first because they appear to be a simpler design. BUT besides less components single ended has bad PSRR and not to mention as you have noticed the price of output transformers, the output iron needs an air gap so the core doesn't saturate with the standing DC current, the air gap then causes the inductance to drop so in order to make up for it they use larger cores and more windings. You can use non air gapped smaller transformers if you go parafeed but then you will just end up spending the money in good quality chokes. Push pull transformers are smaller and cheaper, plus you get more audio watts and better PSRR and distortion cancellation.
Old 17th March 2015, 07:01 PM   #5
I don't trust people who make dedicated detailed web pages about their cats.
http://www.bonavolta.ch/hobby/en/various/cats.htm
Old 17th March 2015, 07:06 PM   #6
I spent $1000 on OPT transformers, worth every penny.
My last SET 10 yrs ago had some "off the shelf" iron and performed poorly.
If your going to build and SET, spend every dollar you can on the transformers.
Old 17th March 2015, 07:10 PM   #7
I wonder how much Magz spent on his Monolith output iron for his 833C amp?
I wish I could find the thread where he posted pictures of them completed......they look sooooooo boss!!!
Old 17th March 2015, 07:15 PM   #8
chrisb is offline chrisb  Canada
+2 on the Edcor recommendation - and don't overlook the excellent circuits and perhaps still parts offering at George's Tubelab
Tubelab | Dedicated to advancing the state of the art in affordable high end audio.
I built one of his SimplePP a few years back - happened to be able to recycle some vintage Scott P/P outputs, and settled on an Edcor power TX - do not try to save money on thermal rating of the Power TX
but yah, iron costs money, then there's the chassis and miscellaneous mechanical and passive circuitry parts that depending on how boutique you wanna go can easily run into several hundreds of dollars.
now on sabbatical
Old 17th March 2015, 07:28 PM   #9
M Gregg's Avatar
So you see,
We don't know if your trying to make Ongaku on the left.. mortgage money
Or something like this middle EL34 and right 6L6..which was a fun project..<<using Edcor..
Sorry just resized the pics..
M. Gregg
Old 17th March 2015, 07:47 PM   #10
K.A.B is offline K.A.B  Sweden
K.A.B's Avatar
+3 on Edcor iron.
I have built an EL84 SE with Edcor opt and all who have listened are impressed but I'm looking to try a pair of Lundahl opt to see if it could be worth an update.
Anders
Worlds Most Expensive Tube Amp !!! spirey Tubes / Valves 25 15th January 2013 02:12 PM
Expensive speakers with dirt cheap DIY-available drivers? uDIYguy Everything Else 5 11th November 2012 04:32 PM
FS: DIY Tube parts, tubes 845's teflon, tube phono PCBs tronan Swap Meet 4 3rd December 2011 01:19 AM
I'm anti-expensive audio parts but man, a good capacitor can make a difference jduffy Tubes / Valves 6 25th April 2007 04:13 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
