Filter Choke Selection - diyAudio
Old 17th March 2015, 05:25 PM   #1
cags is offline cags  United States
Smile Filter Choke Selection
Am Setting up power supply for a line stage preamp. I am using a 350-0-350 CT power tranny, 5ar4 as rectifier and planning on a CLC filter section. Will be using a .47uf 630v as first cap. DCR of choke will be in the 200-250 Ohm range. My question is how to calculate for choke size. Circuit B+ will be 300VDC with current draw of approx 47ma.I have looked at several formulas with no luck. I would like a precise formula to go by.
Thanks Cags
Old 17th March 2015, 06:12 PM   #2
20to20 is offline 20to20  United States
20to20's Avatar
Thanks Cags
Do you mean 47uf cap? What's the purpose of a .47uf cap?
20
Old 17th March 2015, 06:27 PM   #3
Magz is offline Magz  United States
PSUD II is your friend.
PSUD2
Old 17th March 2015, 06:30 PM   #4
Smile Choke Selection
How would I calculate using a .47uf 630v cap ? I was told by using a .22uf or a .47uf cap That I could tweak B+ a little. In any case use any figure you like as a matter of fact and what would be a solid formula to use in determining choke size. That is what I am looking to find out. CHOKE size.
Thanks again
Cags
Old 17th March 2015, 07:01 PM   #5
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
PSUD2
I second that.
However you could also try a capacitor multiplier supply based on a MOSFET.
Old 17th March 2015, 07:52 PM   #6
trobbins's Avatar
Use Duncan tools PSUD2 - you get to choose what component sizes and ripple you are happy with.
Old 17th March 2015, 08:08 PM   #7
F = 1/(2*PI()*SQRT(L*C))
The smaller the first cap the larger the inductor will have to be. Since you are using a 5AR4 you are limited by how large a cap to use so this means a fairly good size choke, 10H with a 47uF is 7Hz.
Old 17th March 2015, 09:24 PM   #8
Famousmockingbird,
Will use formula thanks . Now the 7hz I,m guessing is the resonant frequency. Now the lower the frequency the better circuit stability and a smoother DC ripple. Am I close?
Cags
Old 17th March 2015, 10:05 PM   #9
AllenB is offline AllenB  Australia
Your 0.47uF capacitor is fine. It should leave you with a choke input filter that wants a minimum inductance of (350/50 - Volts / mA) or 7H. If you don't have at least this then your B+ will climb and you lose the tuning you'd get from the first capacitor, and the filtering will behave differently.
7Hz is also a good frequency to go with when you look at the choke together with the next capacitor.
Old 17th March 2015, 10:39 PM   #10
How much voltage do you need ? Unless you need above 300v you will probably be a lot better not using any cap before the inductor. Or as Trobbins already said download Duncan's tools PSUD2 . It's free and easy to use.
PSUD2
Ceramic Filter Selection Eli Duttman Tubes / Valves 21 31st August 2014 12:22 AM
Filter Choke Question Tuberguy Power Supplies 1 15th March 2014 10:09 AM
Help with component selection for filter karha096 Analog Line Level 0 5th September 2013 07:40 PM
Filter Choke BC Parts 2 22nd September 2004 09:36 PM
Choke for Pi Filter lumanauw Solid State 48 5th February 2004 09:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
