Old 30th January 2004, 02:02 AM   #1
Default Need suggestions on tube regulator.
Hello,
I've just looked up the data sheet for these regulators: EZ81, 5ar4, and 5au4.
I need regulator for up to 600VAC input! Do you guys have any proper candidate?
5ar4 is designed to handle voltage up 500V. Is it ok if I use them for my project? But, 5au4 gives more current.
Thanks for all suggestions!
lhchen
Old 30th January 2004, 02:16 AM   #2
first i think you need to change your requirement to tube diode/rectifers regulator are not the same. 5au4 is a damper diode i think which should have higher rating PIV than the other two. I think you need to mention your first cap or inductance value before anyone can comment of the tube required. but 5au4 should be the one if it is the damper diode which i think it is
Old 30th January 2004, 02:20 AM   #3
diyAudio Senior Member
fdegrove's Avatar
It also helps to get the terminology right; diodes, SS or Hollow State, are not regulators...
Frank
Old 30th January 2004, 03:51 AM   #4
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Try looking for damper diodes, some of those RECTIFIERS have pretty impressive specs.
Or a pair of 866A...
(Also just a question, its not a 300-0-300 volt transformer is it? Then GZ34 is your best choice, but any rectifier would do.)
Old 30th January 2004, 10:28 AM   #5
866A *Drool*
Old 30th January 2004, 10:02 PM   #6
Ha!
I have no idea why I called them regulators! I am so sorry. It must be the cold weather lately.
Anyway, I'll check the price and choose one among those rectifiers. Thanks,
lhchen
Looking for the ideal linear SMD voltage regulator, any suggestions? rhysh Power Supplies 2 12th March 2009 02:07 AM
Regulator for tube pre senderj Tubes / Valves 4 13th March 2007 11:17 AM
Tube God TH-1 Amp Regulator PCB ???? Zero Cool Tubes / Valves 7 30th March 2006 10:47 PM
Suggestions for a high-power low noise Zener regulator ? youyoung21147 Power Supplies 0 29th November 2005 11:48 AM
Tube Regulator Jay Tubes / Valves 51 5th April 2003 04:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
