motorola ecl82 3 channel amp? - diyAudio
Old 10th March 2015, 08:01 PM   #1
Default motorola ecl82 3 channel amp?
Hello,
My first post here, I just recently purchased a 3 channel Motorola tube amp it has 4 12 ax7 ,1 el84,1 ez81 and 2 ecl82. I plan on using it as a stand alone amp. and at the same time get rid of the bass channel and just use the two existing channel. My question is did anybody did this mod before and or if anyone has the schematic for it. Thanks and good day.
Cheeh
Old 11th March 2015, 07:18 AM   #2
That console amp is CHEAP. The O/P trafos of the stereo HF sections are too small to handle full range reproduction. IIRC, other manufacturers took the same "bottom feeding" route too.
In order to end up with 2X "full range" stereo channels, new O/P "iron" has to be purchased. I suspect, at the end of the day, you will get to reuse the power transformer and, perhaps, the sheet metal.
Please upload photos of the chassis, focusing on identifying numbers. Those numbers may allow member Tom Bavis to provide the schematic, from his extensive collection.
BTW, you are going to need high efficiency speakers. SE 6BM8/ECL82s yield approx. 2 WPC and SE 6BQ5/EL84s yield about 5 WPC.
Eli D.
Old 12th March 2015, 03:02 PM   #3
VMUNIX is offline VMUNIX  Argentina
What's the model of that console, perhaps it is possible to find schematics and pictures of it.
Old 12th March 2015, 03:11 PM   #4
I don't know which console it came from, I will take a pictue if it when I get home. And yes I'll be using a 98 db effecient speakers.
Old 12th March 2015, 11:05 PM   #5
Pictures, hope this help.
Old 12th March 2015, 11:26 PM   #6
frugal-phile(tm)
planet10's Avatar
Old 12th March 2015, 11:46 PM   #7
I think I can get it running, just waiting for some tubes to arrive, anyways anybody here knows how to by pass the bass channel and try to use it with the left and right channel? Thanks p 10 for the enhanced photo.
Old 13th March 2015, 01:35 AM   #8
Motorola Model SK43M console and HS-835B/9M60 3 channel amp inside. Got the info from another Forum.
Old 13th March 2015, 03:54 AM   #9
Eli is absolutely correct..This amp is a biamp amp for a stereo pair with the 6BQ5 feeding the woofer and the 12ax7s feeding the mids and highs.
Old 13th March 2015, 03:12 PM   #10
Motorola 3 channel console OPT... knockbill Swap Meet 15 24th June 2014 09:30 PM
Motorola 3 channel Tube Amp from Console john65b Tubes / Valves 10 9th June 2013 03:59 AM
Motorola three channel Stvngale Tubes / Valves 28 8th June 2013 04:46 AM
Tripath 5 Channel Amp - Motorola DCP-501 Modified. john65b Swap Meet 8 25th October 2012 04:57 PM
ECL82 Headphone amp mod_evil Headphone Systems 9 8th April 2007 10:31 PM
Copyright 1999-2017 diyAudio
