Help needed on restoring a Bogen AP-200 amp - diyAudio
Old 9th March 2015, 02:15 AM   #1
kotofei is offline kotofei  United States
Default Help needed on restoring a Bogen AP-200 amp
Recently I decided to take a plunge into tubes and purchased a vintage Bogen AP-200. This is an integrated amplifier with 12AX7-based phono stage and phase inverters; the power section uses 4x 7355 tubes and delivers around 25 WPC.
The amp was partially restored by previous owner(s): I was told coupling caps and some resistors were changed. However, electrolytic PS caps are original and I was advised to replace them to get rid of hum. They are C52 (4x 20 mkF/450 V) , C53 (3x 20 mkF/450 V), C54 and C55 (30 mkF/150V each) packed in cans.
I worked on SS amps; however, this is my first tube piece so please pardon my ignorance and stupid questions. How should I change caps that are in cans and what model and manufacturer are preferred? Also, in SS gear people often replace old PS electrolytes with new of higher capacity to get better bass. Can I do it here?
I’ve also read that if a selenium rectifier is used in old amps it should be replaced with a diode and a resistor. Looking on schematics and Bogen itself I didn’t find any; just two old diodes and a new one. Do you think I have a selenium rectifier and should I replace the two old diodes, X1 and X2?
One more thing I’d like to do with the amp is to use it as a preamp or power amp and install “pre out-power in” RCA jacks for this purpose. I think I can do it between Pin 6 of the “mode” selector and the C18/C45 0.01 mkF cap that feeds grids of V3A/V7A (shown by arrowheads at the last picture). The plan is to remove old “Converter output/Third channel” RCA jacks and associated resistors and wiring, install two pairs of new jacks, disconnect Pins 6 of mode selector from C18/C45 then connect it to “pre out” jacks through a new 0.01 mkF/250 V cap. Connection wires will be with screen grounded to “pre out” jacks. The “power in” jack will be connected to C18/C45 with screened wire grounded to “power in” jacks. The C18/C45 cap will be upgraded from ceramics to better type (polystyrene?) 0.01 mkF/100 V.
Do you think it’s the right way of adding pre out-power in jacks here?
In addition I would very much appreciate any and all advises on how to upgrade this amp. I like how its sounds now and I believe it could be greatly improved.
Old 9th March 2015, 02:51 AM   #2
You have to be VERY careful about increasing the total (I read 40 μF.) capacitance in the 1st position of the PSU filter. Vacuum rectifiers will arc over and be damaged at turn on, if that capacitance is too large. What is the rectifier tube type? I'm guessing it's a 5U4.
The schematic shows signs of both cheapness and expenditure. Taking O/P tube B+ off the 1st filter position is cheap. OTOH, Bogen did spend on a DC heater supply for the small signal tubes. If a choke of about 1.5 H. and appropriate current rating can be "shoehorned" into the chassis, the filter feeding the O/P tubes can be made CLC, instead of just C, which allows the reservoir position capacitance to rise. A choke isolates the vacuum rectifier from the remainder of the PSU filter.
I don't know if replacement 7355s can be sourced at "reasonable" cost. A quick look at the 7355 data sheet suggests you might be able to rework around EL34 class tubes. Get the opinion of an EXPERT, like Jim McShane.
Replacing all of the SS diodes with Schottkys of appropriate rating is (IMO) a good thing. You definitely get rid of any ticking toxic time bomb selenium and, unlike other SS diodes, switching noise free.
Eli D.
Last edited by Eli Duttman; 9th March 2015 at 02:55 AM. Reason: added Schottky remark
Old 9th March 2015, 03:12 AM   #3
kward is offline kward  United States
I would replace the top mounted can capacitors. Antique Electronic Supply has a large selection of replacements. Look for the brand "CE Manufacturing" for starters, but you don't "need" to use those. Other options are the dual can capacitors from F&T or JJ/Tesla, and the remaining capacitors needed not in the can itself can be soldered under the chassis. You can also restuff the old cans with small modern electrolytics, but I find this is much harder. Make sure the first cap right after the rectifier is no larger than what is recommended on the rectifier data sheet.
Old 9th March 2015, 03:35 AM   #4
Here's one I did. Blocked off the original filters and put them inside, save for the last one that's under low stress and measured good for value, loss and leakage. If you can't prove it beyond a shadow of a doubt, replace it. Note added fuse and terminals for bias supply parts. In hindsight, I'd use a bit higher fuse.
I may be barking up the wrong tree, but at least I'm barking!
Old 9th March 2015, 01:58 PM   #5
Tom Bavis's Avatar
Adding a fuse is absolutely essential! I can't believe the Bogen didn't use one!
The preamp out will have a very high impedance, and may roll off highs due to cable capacitance. For example, look at the cap values in the high filter - 10s of pF. Most cables are around 20 pF per ft.
Old 10th March 2015, 12:47 AM   #6
Thank you everyone for good suggestions,
The 40 uF is C52A+C52B, right? So I suppose using of one 40uF cap instead of 2x 20 uF will be OK.
It’s a GZ34; I have a new JJ GZ34S.
… If a choke of about 1.5 H. and appropriate current rating can be "shoehorned" into the chassis, the filter feeding the O/P tubes can be made CLC, instead of just C, which allows the reservoir position capacitance to rise. A choke isolates the vacuum rectifier from the remainder of the PSU filter.
I don't know if replacement 7355s can be sourced at "reasonable" cost…
The 1.5 H choke unfortunately wouldn’t fit underneath the chassis. Smaller choke of 0.5 H or so might; however, how big will be benefits of installing it?
Regarding tubes, I do have a spare quad of 7355.
…Replacing all of the SS diodes with Schottkys of appropriate rating is (IMO) a good thing. You definitely get rid of any ticking toxic time bomb selenium and, unlike other SS diodes, switching noise free.
Selenium rectifier should look like a little stack of cards, not like a resistor or cap or diode, right? If this is so, there is no such rectifier in the Bogen. The X3 diode is already replaced with IN4007 by previous owner(s). X1 and X2 left; I might replace them with IN4007s. Are they Schottkys?
I am going to install a fuse and also a new socket for the three-prong cord, attaching a green "ground:” wire to the chassis. The reason for this is that the Bogen manual explicitly says: “Ground the unit by attaching a wire from a COM terminal on the chassis rear to a good ground such as the metal frame of the wall outlet or a water or steam pipe”. I might even have a three-prong socket with the fuse holder sitting around. The two power outlets at the rear and the "death cap" C56 will be removed.
…The preamp out will have a very high impedance, and may roll off highs due to cable capacitance. For example, look at the cap values in the high filter - 10s of pF. Most cables are around 20 pF per ft.
Thank you for pointing on this. Actually, I am much more interested in using Bogen as the power amp than as the pre. However, is it any way to lower tube amp output impedance?
By the way, high and low filter switches will be bypassed to improve the quality of sound: fewer switches, especially old, less connections, less signal losses. Very few people use these filters now and I am not one of them.
Old 10th March 2015, 01:55 AM   #7
A GZ34/5AR4 is supposed to be able to take as much as 60 μF. Unfortunately, all of JJ's Octal production is unreliable and highly suspect. Definitely install the SS diode tweak, as shown in the uploaded graphic, but use UF4007s, not 1N4007s. I suppose a 47 μF. 1st filter cap. will be OK.
The 1N4007 is a very noisy PN junction diode, rated for 1000 PIV. The UF4007 is a drop in replacement for the 1N4007 that's MUCH quieter. Obviously, a 1000 PIV part is overkill in the low voltage heater and bias supplies, but certainly does no harm.
Eli D.
Old 10th March 2015, 02:13 AM   #8
Thank you Eli,
After doing this diode tweak, should I completely remove the GZ34 rectifier tube? Alternatively, if JJs rectifier tubes are unreliable, perhaps I need to get one of other brands instead?
Old 10th March 2015, 02:37 AM   #9
The SS diode tweak augments the vacuum rectifier, but does not replace the tube. The "sand" provides some extra PIV headroom. Current production 5AR4s are not all they should be, but the cost of NOS is hideous. Use the JJ tube, after adding the tweak to its socket. If the JJ product gives you trouble, such as arcing, replace it with a Sovtek.
Eli D.
Old 10th March 2015, 04:39 AM   #10
trobbins's Avatar
Can I suggest:
Add an AC fuse, and also fuse both HT secondary winding arms, not the CT, as there may be an issue with bias supply if a CT fuse blows.
1N4007 should be fine for the augment job, because the valve diode will inhibit reverse current flow.
You could decouple the output tube grid bias at the balance adj pot ends, and also add in some protection resistors from wiper to pot ends - unless you're happy to guarantee the pot's performance :-). A 1 ohm cathode sense for each output valve may make it easier for you to set up the amp.
It would be interesting to identify all the schematic errors (eg. R31, 71) and if the output windings are grounded as shown.
Bogen mo-200 SS64 Tubes / Valves 0 10th October 2013 04:18 AM
Bogen L330 - Worth restoring? Nodric Tubes / Valves 0 22nd April 2012 01:05 AM
Bogen AP-35 Static and Pop from one channel eelsid Tubes / Valves 1 9th March 2011 04:09 PM
WTB - Bogen MO-100 or Stromberg Carlson AP-55 el34guy Swap Meet 1 26th February 2011 09:02 PM
Major modifications of a Bogen AP-35 Binaural Tubes / Valves 19 8th April 2010 06:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
