Heath Williamson type W-3M - diyAudio
Old 8th March 2015, 01:30 PM   #1
jackinnj's Avatar
Default Heath Williamson type W-3M
I purchased a pair of these several years ago, the capacitors had been replaced so I felt no pang of guilt in probing around the innards. Found that many of the carbon comp resistors were more than 20% off spec, so replaced with Panasonic 3 waters, or Vishay RN60.
The feedback is different from the Heath manual, will describe when I trace it out.
Old 8th March 2015, 01:44 PM   #2
SY's Avatar
About 0.12% distortion, not bad. A little tweaking and you could null out that predominant second.
"Pity, wrath, heroism, filled them, but the power of putting two and two together was annihilated."- EM Forster
Old 8th March 2015, 02:18 PM   #3
artosalo's Avatar
At what power level the FFT was measured ?
Old 8th March 2015, 02:44 PM   #4
smoking-amp's Avatar
W-3M
The W-5M puts an extra series R-C damper (Zobel network) across the secondary.
Old 8th March 2015, 09:23 PM   #5
trobbins's Avatar
Does the PT CT go to cap neg or to star gnd? The PT CT really should be fused, if you've jumped the moral hurdle of changing out resistors.
Old 9th March 2015, 12:52 PM   #6
jackinnj's Avatar
5 watts into 8 ohm.
The feedback network is 12k||100pF rather than 6.8k||33pF. This unit also has the 47k load resistor on V1 paralleled with 1k+510pF. I've seen this in other Williamsons, so Heath may have had stability issues with the early models.
I replaced the carbon comp 27k resistors for V2 with 27k Panasonics matched to 0.1% The originals were a little worse than 1%
Each 5881 is running @60mA.
The output of the amplifier was also attached to the 16R tap, but was driving 8R. This is perhaps the most significant change.
Old 10th March 2015, 12:51 PM   #7
jackinnj's Avatar
Little more tweaking -- changed the DC balance a bit and the 2nd is down to -79dBRa. Also included the schematic with the parts which differ from the original W3:
Old 10th March 2015, 04:54 PM   #8
jackinnj's Avatar
OK, I'm done with this one:
Old 10th March 2015, 08:30 PM   #9
trobbins's Avatar
Was post #7 also at 5W ?
The 3rd harmonic is almost below the mains harmonic modulation of the signal. I guess a contributor to the rise in THD with output power would be a rise in the mains harmonic modulation level as the power supply gets worked harder.
Old 10th March 2015, 09:48 PM   #10
jackinnj's Avatar
Yes -- that's the point at which the Heath W-3M manual specifies THD%
As you see, I ran it up to 20W.
I could do a low frequency FFT at different power levels, 1Hz to 300 Hz
Heath sink size tony Ma Pass Labs 4 24th March 2013 10:31 AM
can i get by with a heath-kit o-scope? AKHeathen Equipment & Tools 5 22nd September 2011 01:57 AM
Uge Heath sink Bksabath Group Buys 7 30th October 2010 05:14 PM
Looking for a Williamson squematics burtcheca Tubes / Valves 7 3rd July 2010 11:20 AM
Another Williamson floyd carter Tubes / Valves 3 20th February 2010 02:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
